One BBl Carb Question
Old Jul 16, 2007 | 03:55 PM
javi2001's Avatar
javi2001
Yes ! Remove cover and put it upside (180º rotation) the float will hang over needle valve by its own weight. The level stated on charts will put the float parallel to gasket surface, in my experience this is a bit high, reduce a little bit and try againg
Old Jul 18, 2007 | 02:51 AM
PaulzF150's Avatar
PaulzF150
Thanks Javi2001! Maybe I'll try to do this on the weekend. Lately, it has been hitting over 110 degrees Farenheit. Not the best weather for tinkering. Thank you for all your help and information.
Old Aug 27, 2007 | 03:13 AM
PaulzF150's Avatar
PaulzF150
I adjusted the float to specs and still had the same problem. However, the accelerator pump diaphragm was looking rough and perhaps was letting fuel get past it. So I replaced the accelerator pump diaphragm, and now the truck is running smoothly. Thanks everybody for your information.
Old Aug 27, 2007 | 07:35 PM
javi2001's Avatar
javi2001
OK nice you found the problem. I totally forgot mention the accelerator pump, this is a common problem but I never had it...
Old Aug 28, 2007 | 02:45 AM
PaulzF150's Avatar
PaulzF150
It is a good thing that I had an extra carb around as I accidentally broke that little black plastic tube that is hooked up to the accelerator pump! The truck runs smooth, but now I have to address the high idle problem I am having. I think something is messed up with the linkage, as the idle screws being backed out doesn't slow it down. It is supposed to hit 110 degrees F. tomorrow, so I'll wait until next weekend. This truck isn't a daily driver, so I don't have to be in a hurry to fix it.
Squirrel Man Sam
Jun 30, 2023 01:05 PM
JayzDaddy
Nov 28, 2014 07:43 PM
Pitcrw6
25
Dec 9, 2012 04:28 PM
Dave967
Jul 15, 2011 10:22 AM
jmsurpri
May 24, 2000 05:52 PM
