help please I have 1994 ford f-150 /5.0 I can not find what the spark plug gap
is for this engine can anyone help me thank you all for all your help in the past
I looked under the hood of my 92 F-250 and found no sticker for spark plug gap, but the Haynes manual says for 1980-1996, all engines, .044.
Makes one wonder which is correct. Call local Ford shop maybe.
Most of the 94+ MAF equipped trucks I worded on called for 54. Both the stickers on mine say 52-56 so 54 it is .
And as far as both those manuals I think they stoped updating in 92 . I bought new clinton (in 2006) because my other manual only when to 93 (had it that long) anyway they don't even have MAF or OBDII
I got ford manual on CD from local Dealer (freebee)
If there's a range for the plug spec, go with the lowest number...spark plug gaps only get bigger (unless you're losing chunks off your piston, but then you have bigger problems). If you start at the lowest number, it will stay in spec longer. Most every Ford truck from this era I've seen is 0.042-0.046".
I like it when we find a fault with the manuals and we need to get more info to document this. so if every one reading this thread could post what engine they have and the year of truck and the gap that is printed on the sticker under the hood of the truck we will all see what is going on here.
