The pressure had been low, and after checking it with my old regulator removed, was it found to be 80-90 PSI.
Thats when I got the new regulator.
I then moved on to the Idle control Motor,
since it was running rough, but maintained an idle.
After replacing it, is when it ran smoother but now stalls.
Not sure how you ever got the 80-90 PSI. Did you put a gauge on the pressure line from the tank without the line going anyplace else?
