which 4spd behind 69 360?
For a keeper truck look into a TKO 5 speed with 5th as OD in two different ratios plus rated at 500 and 600 ft/lbs torque.
Weight and money not an issue go for a Clark 5 speed, not in my truck. The Stooge NV 4500 can be "Afro Engineered" to make fit, they had failure problems even new from Stooge. Yeah just what I want to run, not.
My pin and it's locating groove are in top shape so far. :)
To improve the "feel" of my T18 I've added washer-like parts to compress the spring farther and keep it centered and to isolate the spring's ends from rubbing on anything. Also i cut a groove around the gear shift lever to accept a retainer ring to help with all that.
That might not have anything to do with the feel you're talking about tho? :)
Seems like I added a spring inside the original spring too, one that "coils" the opposite direction of course. :)
When working in the machine shop back in the late 70's I made myself a gear shift lever extension and re-bent the gear shift lever (using a cutting torch as a rosebud) so there is just enough room for my hand and **** to clear the steering wheel while shifting into 1st. Also the **** is just forward enough so my elbow almost touches the seat back when shifting into 2nd.
http://www.panix.com/~alvinj/file12/gearshift.jpg
(shown in 1st gear)
You can see where the two come together at the bottom edge of the picture because the lever's edge was chamfered and so is the extension to match.
The gear shift lever has a angled shoulder around the threaded part and I copied that -in reverse- inside the extension. :)
I'm a weird one... much shorter people than me, put the seat farther back ...usually all the way back. :/
i don't like "reaching" for the steering wheel is all. YMMV
Having set up a few dune buggies "for feel" has made me notice that ergonomic crap? ;)
Alvin in AZ
1st and reverse varied and so did the 2nd and 3rd looks like... at least according my research on the subject.
Ford does that you know. ;)
3.25 is plenty with 235/85-16's.
If you don't go crazy you can easily skip 1st gear and make an "easy on you" 3 speed.
Sounds like you'd be better off with a T19 they have taller ist and reverse.
Alvin in AZ
The 76 4X4 tranny is in the shop for repair. Too much vibration and metal filings on the magnetic plug, so I took it out. This tranny was run by various agencies unknown to me before I got the truck, so I can't say what abuse it endured. But I did have the aforementioned Bronco for 15 years, and that NP435 never gave me any trouble.
Off the top of my head as i'm into C-6 tranny trucks the last 8 years what I did to 435 boxes for 30 years is below.
First off the aluminum cover is a POS which wears and becomes a sloppy mystery shifter over time and mileage with loose side pins, replace with new then later seal top and retainer from dirt wear and water. Best to tap and installed allen bolts for pins with ends machined down with lock nuts, allen pins are hard as hell.
Shifter top, check and replace the interlock plungers if needed between the interlock ***** as factory are too short allowing 2nd to R engagement at the same time hence "locked up box". This can be corrected if on the road by removing shifter then relocating shifter gates to neutral position, reinstall shifter and go. Done many times until pissed off and corrected.
The newer shift lever has the shift ball suspended around "O" rings to allow for less cab noise and shifter vibration but allows for less synchro feel and action, again a "new" POS idea that sucks.(JMO).
Remove "O" rings, clean and epoxy the ball extension to the shift lever after it has been centered plus reinstall factory roll pin.
On a box with high mileage (500K plus) even with the replacement thrust washers the cluster gear has end clearance, make bronze spaceres to the correct end clearance.
If saving old internal parts like synchro rings spend app 4 hours with a Dremel and dress every tooth maintaining factory angle but smoothing worn and chipped areas, smooth and polish only.
Sand drums with 220 paper, aluminum synchros last so replacement isn't needed nor cheap I have found even on a high mileage box.
Take the #308L bearing with 7 ***** and chit can it, replace with a 11 ball this will help handle the axial thrust better from the input bearing, bad bearing combo of taper pushing against ball.
Set input shaft to just a detectable end clearance, too tight and the internal parts will expand more than the case hence hard shifting, thrust bearing preload and failure due to heat, too loose then ya got a "milk truck" sloppy box. The taper bearing will lift from the cup causing vibration and noise problems.
With this set check with feller gauges, note two one on each side and check your synchro clearance. I recall it was .055" don't quote me on this. Lower the mininum spec by again 10%, this allows for a sooner applied synchro action and wear before drive dog engagement hence smooth crunch free speed shifting.
All the above with a new clutch and pressure plate with no reman crap.
If a long arm check the arm travel for loose linkage and equal, better if custom reamed and repinned plus adding interchangeable weights.
Even with this rework applied on a 4.10 geared 414 motored F250 it would eat 435 boxes if driven aggressively within 500 miles.
Good box yes but not a great bullet proof box, hell it's only rated 327 ft/lbs,
speed shifting is way above that rating.
I ran 80/90wt gear oil adding 30-40% Honda Motorcycle Racing transmission oil which is a high shear gearbox oil which is app 25wt.
This will thin down 80/90wt gear oil without the loss of oil shear strength plus the added protection reducing gear face galling.
This combo must be working as old truck passed 922K two years ago with new owner and still working hard.
All the above are what has worked for me, your on your own on what you do and use.
Your NP435 I would guess would have 6.69:1 first.
You can have a T-19 with 4.02, 2.4, 1.4, 1.0 or 5.1, 3.0, 1.8, 1.0
or with a 6.32:1 1st as used in 460 4x4's for a few years.
And if you think I'm kidding, well here you go~
http://www.geocities.com/spookytruck/trucks.html
