in its stock location..it will be moved this weekend if i get time or next..i was up till midnight the other night doing the install..ran out of time..
Good job Ron! You noticed fast spool-up? I didnt notice anything except maybe cooler egts. Wait until you get a HPOS, then you will notice a difference!
thanks guy's.. i learned something from painting the pipes..i should have known it would happen dont paint and use clear coat where the boots go..they will blow off...
thats one nice job Ron, i hope you happy with everything,
every thing works great pete..thanks a lot. .i couldnt have done it with out you..i got a new EBPV repair kit, the wicked wheel..new boots .plenums and all the orings ..i did the ccv mod this morning..now i need the 17* HPOP..
Great work Ron. Looks good. Did you have to "rough up" the tubes at the connection?
thanks tenn..yes i did..the clear coat made the pipes too slick..sanded them back down where the boots are and all is well..built a boost detector and put 40lb to her and she held up well....
Yeah, I forgot specifically who did it, but I saw a member powdercoat their pipes once and then after powder coating, he taped the WHOLE pipe except for two inches on each end and then had the ends bead blasted with a very fine media. It left a very definitive transition from coated to non-coated and the coarse surface left by the blasting keeps the boots from blowing.
