Rear end issue
Old Jun 21, 2007 | 04:34 PM
zpmps2's Avatar
zpmps2
Rear end issue
Hi again guys, along with my other question, i was changing the rear end oil today Ford 9 3.L50 Gears, if that makes a difference, and i found the plug on the right side, if your looking at the front, is this the fill plug, if so, do i fill it up till it almost overflows, and also where is the drain plug, or how do yall do it, since i cant find a drain plug, i let the bottom 9/16 bolt out, not the nut, but right after the yoke goes in, i let the bolt out, and nothing came out, was something suppose to come out, if its full? thanks again guys, and i need fast re post for my truck is up on jackstands and i need it this afternoon, "go to the junkyard as i posted in my other question, "see below"
Taylor
Old Jun 21, 2007 | 05:03 PM
85e150's Avatar
85e150
No drain plug:
-pull axle, pick up truck and tilt to that side. Shake to remove last drops...
-use suction device through fill hole
-loosen nuts holding to housing and crack it loose. Wait days for an incomplete drain, and hope the gasket seals again.
-pull the entire unit and clean it out with suction and rags
On refill, yes, fill till it's at that hole.
Old Jun 21, 2007 | 05:32 PM
zpmps2's Avatar
zpmps2
Originally Posted by 85e150six4mtod
No drain plug:
but the bolt on the bottom, if i open it up, is fluid suppose to come out?
Old Jun 21, 2007 | 10:07 PM
Franklin2's Avatar
Franklin2
It's probably a blind hole and that's why the fluid won't come out.
The fastest way for you to change the oil is to get one of those suction tools at the store and suck it out. You can then clean it up and use it to suck the oil out of the new oil container and use it to put the new oil back in the side hole. On level ground, fill it till it runs out the hole.
Old Jun 22, 2007 | 10:35 AM
zpmps2's Avatar
zpmps2
okay, my neighbor, big ford guy, and his son, also big on ford, told me to spray the hell out of it will brake clean after i got all the oil out, then drain it, b/c im going from 80w90 to my new lucas oil 85w140 for no reason other than pulling haybales, so should i use breakclean or what.
Taylor
Old Jun 22, 2007 | 11:00 AM
mtflat's Avatar
mtflat
I'd only clean it if you find lots of grit in the sump. And then, only if you pull the carrier chunk off so you can actually get to the bottom of the housing and get the solvents back out. You won't be able to do that with a suction gun.
Also, I'd stick with the recommended 80w90 lube AND be sure to include the additive slip-plate for your limited slip clutches. The other lube may interfer with your clutch pack operation. The 9" will handle hay bales easily as it stands. Other components will fail first.
Old Jun 22, 2007 | 11:06 PM
Franklin2's Avatar
Franklin2
Yes, I would not use solvent, because you can't drain it.
Old Jun 23, 2007 | 02:37 PM
zpmps2's Avatar
zpmps2
15-20 Thousand pounds of them, 15-20 haybales, 1000 pds peice, i just dont want anything overheating and the ford guy said that 85w140 wont hurt it and has a greater chance of not "overheating" my limited slip doesnt work, arent you suppose to engage the parking brake a little then go, but my parking brake is froze or something, to overtightend is what my dad said, how can i fix this, and what kind of additives for my 9, and i have already bought the 85w140, should i take it back and exchange or will it hurt it?
Thanks
Taylor
Old Jun 23, 2007 | 06:07 PM
mtflat's Avatar
mtflat
Taylor, the 9" rear end is just about bullet-proof. It's the best differential Ford ever made and will handle 1000 lb round bales. (I live in farming/horse country myself) You might have trouble getting enough traction at the wheels, but you won't have differential trouble. I honestly believe you'll break u-joints or burn up your clutch before you hurt the rear end.
(however I have stripped the axle splines and side gears twice on that same rear end, but that had nothing to do with fluid viscosity - my 86 has 315,000 miles on it)
I don't suppose the 85w140 will hurt anything, it just isn't necessary. It would help most with high-speed long distance driving. The additive you need to add to a limited slip diff (9 3L50) is called a "friction modifier" and the Ford part number is C8AZ-19B546-A You should be able to get the equivalent at NAPA. Add 4 ounces in your diff fluid. It allows the disks to slip properly as it engages.
btw, the parking brake problem is probably due to rusted cables. Put new cables on it and you should be back in business.
ltd slip works as an open carrier most of the time until one wheel slips and the clutch pack distributes power to both wheels. You won't see it until you need it - provided your clutch pack isn't worn out. They do need to be replaced from time to time.
Old Jun 23, 2007 | 08:11 PM
zpmps2's Avatar
zpmps2
ok, i did buy the 140 for long trips, and before i posted i had already spent the $ buying it. Yes, i know it will handle 1000 pds in the bed, but 15-20 thousand pounds on a gooseneck, this is why i bought 85w140? how will it hold up to this, already had to replace u-joints, so thats a check mark, will it be neccesary to put new cables in, i know the 67 lim slip, you have to engage the park brake slightly, is it neccesary for the 9's, thanks again guys, i really appreciate it.
Taylor
Old Jun 23, 2007 | 08:43 PM
mtflat's Avatar
mtflat
Ignore what I said about traction - I was thinking about pulling them around a feedlot with the truck. Didn't even think of trailering them - brain dead for a moment - Around here they haul multiples with semi's.
I still think you'll be ok. Make sure to have working trailer brakes on the gooseneck. The half-ton is on the small side for loads like that, but if you take it easy........
Franklin2's Avatar
Franklin2
I don't know what you are talking about here. The 1967 would have the same 9 inch rear as the one you have now if it was a 1/2 ton pickup, and regardless, I have never heard of any type of limited slip for any type rearend needing the parking brake cable pulled to activate it.
Sounds like you are applying the parking brake to put drag on the wheel that is spinning, thus sending more torque to the wheel that is not. This has nothing to do with a limited slip rearend.
Put any type of gear oil you want in there, just so it has some. I can't believe sometimes the advertising hype that goes along with some of these oils.
Old Jun 23, 2007 | 09:48 PM
zpmps2's Avatar
zpmps2
yes, it is a small side for loads, but i need to transport them 2 miles or so on backroads, nothing else, my neighbor carried a D6 dozer on a flatbed gooseneck on his 78 F-250 w/ no trailer brakes, in 4 lo, you just have to crawl around town, so i will, like you said, will be pulling them around the feedlot for offloading.
Thanks guys, and ill keep you posted, going to get the sunction tool at Auterzone tommorow after church, then maybe NAPA
Old Jun 23, 2007 | 09:51 PM
zpmps2's Avatar
zpmps2
i dont think its a 9 inch, but i was wondering if i had to do this for mine, ill copy the page and put it on here, im not lying, and we tryed it on gravel and pavement, with the 67, and it peglegged both surfaces until we locked em, on the pavement, it jarred the heck outta us and it ran crappy after it, and we tryed to think of a way to tell him in the morning, it was 1-2 am, and when we went out to the truck to tell him a wire off the ol 6 was off of it, this would explain!!!!
Old Jul 3, 2007 | 10:03 PM
zpmps2's Avatar
zpmps2
ok guys, its been a long time since i said tommorow after church, but i just got into town today, and i picked up the suction tool at AutoZone and they had the Limited Slip/Posi Trac fluid their, so i bought that, "20 Miles to Napa" and didnt want to waste that gas going to the "BIG" Town, so do i put all of it in their, or just some of it, OR How many ounces of it are you suppose to put into it, b/c my :Barn/shop: is a long walk away so i wont be going their til morning, so how much goes in for a 9 inch?
