fuel gauges
Old Jun 21, 2007 | 12:54 PM
1988midnightblue's Avatar
1988midnightblue
fuel gauges
My fuel level guages do not work. The front tank used to work and the back used to be all the way passed E. Now the front tank is pegged and so is the rear. Any clue on what is wrong. This truck has been very good for me and I've never had to work on it so I don't know much about it. Please help. I'm wanting to sell this baby so I want it fixed for the new owner.
Old Jun 21, 2007 | 01:00 PM
pfogle's Avatar
pfogle
When you say pegged you mean all the way on full or all the way on empty? Start by checking the wiring AT the tank, there is a ground wire for each tank, make sure it's still connected to the frame and that the connector and wire are in good shape. If not replace the wire where needed and/or the connector.
Old Jun 21, 2007 | 01:04 PM
1988midnightblue
Pegged to full. I've heard that it can peg if the ground wire is broken or has lost contact but I'm not sure where it is. Would replacing the g-wire be an easy fix. I sure hope so.
Old Jun 21, 2007 | 02:05 PM
subford's Avatar
subford
The fuel tank ground (G801) is located on the left hand (driver side) inner fender behind Headlamp.
The fuel tanks (or anything else.) do not ground to the frame.
Old Jun 21, 2007 | 02:18 PM
1988midnightblue
I will check that out. Hopefully that fixes something. Thanks.
mike L
39
Nov 23, 2014 09:33 AM
Charlie01
Mar 22, 2011 06:51 AM
rjaywhit
Oct 7, 2009 09:03 AM
89f150mike
Oct 8, 2007 09:47 PM
k3ke
Feb 2, 2002 06:57 PM
