Won't crank!
Old Jun 21, 2007 | 09:59 AM
Goldenboy's Avatar
Goldenboy
Unhappy Won't crank!
Tuesday problem with smoke. (See thread "Thick smoke")
I found an extra fuel filter just upstream of the fuel pump. I drained the water separator/filter in order to change the extra filter.
Now it won't crank. I just get one clunk, no rotation. Can air in the fuel line cause this?
Batteries show full charge with Minkota tester (I don't have a hygrometer). Battery connections are good, just cleaned and tight.
What to do?
Old Jun 21, 2007 | 10:20 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Nope. Check relay and connections at the starter. Maybe turn the crank some via the nut on the balancer and see if it will engage.
Old Jun 21, 2007 | 10:24 AM
nlemerise's Avatar
nlemerise
No, air in the fuel line will not prevent the engine from cranking over. I'd guess the clunk you are hearing is the starter relay...but usually I hear that described as a click. Try turning your headlights on and have someone watch your lights when you try to start the truck. If they dim considerably it would indicate a battery problem or a connection problem. Be sure the starter to relay cable is clean and tight. Was the truck running alright the last time you shut it off?
Old Jun 21, 2007 | 10:33 AM
Goldenboy's Avatar
Goldenboy
Not running well last time it started, excesssive smoke. Changed the extra fuel filter since.
I think the clunk is the starter motor trying to crank.
Old Jun 21, 2007 | 10:51 AM
Tenn01PSD350
CAUTION!!!!! I just reread this. Do not attempt to start the truck while turning the crank with a socket. I hate to say this as it appears to be common sense but I would sure hate to see someone get hurt. Sorry.
Old Jun 21, 2007 | 10:57 AM
fbilly420's Avatar
fbilly420
your starter could possibly hanging up try having someone hold the key to crank and you crawl under the truck and tap on the starter body with a hammer this will sometimes free the starter up and let it spin.
Old Jun 21, 2007 | 11:27 AM
just another truck's Avatar
just another truck
even just tapping on it your self may free it up.
Old Jun 21, 2007 | 01:59 PM
mustang_gt_350's Avatar
mustang_gt_350
Mine just did this to me this week. Cleaned up the battery terminals (for the 2nd time in 2 weeks) and put some terminal grease on them and really tightened them up. and bang fired right up. But when mine was doing this my dash lights where low on power and very dim including the WTS light.
Old Jun 21, 2007 | 02:21 PM
HKusp's Avatar
HKusp
I think your point was; turn the crank with the socket. Get the socket off the crank. Get out from under the truck. Then attempt to start the truck.
Old Jun 21, 2007 | 05:25 PM
Goldenboy's Avatar
Goldenboy
Well, got it towed to the dealer. Turns out there was a short under the vavle cover, and a fire which fried the #8 injector, which leaked fuel into the cylinder, filling it completely. Would not crank due to hydraulic lock.
Looks like about $1500 to fix. 3 wiring harnesses, new injector and labour.
Thanks to all for the helpful suggestions.
BTW, I could not turn it with a wrench, of course. And I knew eneough not to leave the wrench on while cranking, not that it would have cranked anyway,LOL.
Old Jun 21, 2007 | 05:32 PM
rbaker6336's Avatar
rbaker6336
guess you found thick smoke problem also
Old Jun 21, 2007 | 10:52 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
So Glad to hear you got the problem fixed. Lucky that the fire didn't catch much else on fire, with all that open fuel and the vented crankcase gasses. Whooewww count your blessings. That's expensive for what you're getting, new injector and seals for $150, the valve cover gasket and harness for $100. Labor a few hundred... Wow
