Sponsored by: Innova
more bass!!!!
Old Jul 2, 2007 | 04:04 AM
78F150XLT's Avatar
78F150XLT
what ever they are loud as hell
Old Jul 5, 2007 | 08:48 PM
04F-250 stroked's Avatar
04F-250 stroked
Originally Posted by Beerstalker
It looks like that amp wants a load of at least 4 ohms. So if you are only going to run one sub you will need to get the dual 2 ohm voice coils and run them in series to give you a 4 ohm load.
Rockford Fosgates subs are fairly decent, as are MTX, Polk, and Infinity. My personal favorite lately has been Image Dynamics, but they are a bit harder to find as they are a small company.
Check out SuperCrewSound. They are a site sponsor and sell custom boxes as well as Image Dynamics subs. I had an IDQ10D2V2 installed in a JL Audio Stealthbox in my 99 F250 and loved it. I will be putting it in my 07 F350 when I get around to installing the audio stuff.
I bought 2 idq10's 4 ohm with the supercrewsound's box that you recommended. Now my next question is how do I wire these up? Series or parallel? I’m a complete noob to this so please be patient.
Old Jul 5, 2007 | 10:15 PM
Beerstalker's Avatar
Beerstalker
I would run the voice coils in parallel so each sub is seen as a 2ohm load, this should be explained in the instructions you get with the speakers. Then depending on the box I would either run each one off a seperate channel or run the two subs in series bridged across the amp. If the box has two seperate chambers, one for each sub I would run each on a seperate channel. If the air is open to flow between the subs I would run them in series.
Old Jul 5, 2007 | 10:16 PM
mr_malina's Avatar
mr_malina
Single coil or dual?
Old Jul 6, 2007 | 12:02 AM
04F-250 stroked
duel coil.
Old Jul 6, 2007 | 05:53 PM
mr_malina's Avatar
mr_malina
This is the basics. Hook the two positives together on one subs and the two negatives and run those to one side of the the two channel amp and then repeat for the other. This drawing I found online and is basically what it should look like.
Old Jul 6, 2007 | 10:12 PM
04F-250 stroked
<TABLE><TBODY><TR><TD vAlign=top width="100%">thanks guys i'll be posting when i get them in.
Thanks for the help
</TD><!-- KEN: 1-13-2007: show 300x250 ad-block to non-Club FTE users in the 1st post of every page --><!-- Ken 2-8-2007: only if not club fte member in --><TD vAlign=top align=right width=305>
</TD><!-- / Ken, end of hack --></TR></TBODY></TABLE><!-- / message --><!-- no sigs except when logged in --><!-- sig -->
__________________
Old Jul 13, 2007 | 09:18 AM
riggz's Avatar
riggz
how you wire them depends on your amp. maybe im blind, but did you post up what amp you will be using?
Old Jul 13, 2007 | 09:40 AM
mr_malina's Avatar
mr_malina
amp info:
Here are the specs for the PC2150:
Power Output:4 ohms 150W x 2
Power Output:2 ohms 300W x 2
Power Output:4 ohms Bridged Mono 600W x 1
THD: 0.02 %
Signal/Noise Ratio: 115 dB
Frequency Response: 4.5 Hz - 100 kHz
Sensitivity: 0.15 V - 12 V
Damping: > 500
Crossover Slope: 24 dB/Octave
Crossover Frequency: 90 Hz
Crossover Type: 2 Way
Internal Fan: Yes
First post on page 1.
Old Jul 14, 2007 | 09:37 AM
riggz's Avatar
riggz
ah ok, so yeah i'm blind! lol.
you will def. want to run each speaker in parallel. with dual 4 ohm subs that would create a 2ohm load per channel at the amp.
Crutchfield has nice diagrams:
Old Jul 15, 2007 | 05:14 AM
04F-250 stroked
If I understand the diagram correctly i would only be using 1/2 the power.
2 x 150 @ 4ohms vs. bridgeing it down to
1 x 600 @ 4ohms
I found a slightly diffrent diagram (bridged vs. 2 channel) on another site but i need help posting it.
Old Jul 15, 2007 | 12:37 PM
riggz's Avatar
riggz
you would be using full power. you stated you have two 4ohm dual voice coils correct? wiring each speaker's coils in parallel would create a 2ohm load per speaker. so you have two 2ohm loads at the amp. one for each channel. where channel 1 = 300watts @ 2ohm and channel 2 = 300watts @ 2ohm. this would give you the ability to hear it in stereo.
your other option is to run the voice coils in series and the spearkers in parallel. that would give you a mono/bridged sound using 600watts @ 4ohm (which is essentially 300watts to each speaker.) here's how to wire it this way (Option 2):
Old Jul 15, 2007 | 01:57 PM
  #28
04F-250 stroked
what are the pro's and con's of running it bridged vs. stereo?
Old Jul 16, 2007 | 01:23 AM
  #29
riggz's Avatar
riggz
there will be less work load on the amp using it in stereo. 4ohms is greater resistance vs. 2ohms. it's also technically supposed to be louder on paper, but let your ears be the judge.
Old Jul 16, 2007 | 05:28 PM
  #30
Beerstalker
As I mentioned before, if the box does not have two seperate chambers, (one for each sub) you are better off running the subs bridged in parallel like option 2 in rigzz post #27.
