pwr steering id
Old Jun 20, 2007 | 04:17 PM
awfulaggravated's Avatar
awfulaggravated
pwr steering id
this ones right up numberdummy's alley , i kinda see on the pump c7ar-ba587 ? anything close? the ahh, previous owner installed, on 1966 f100, she leaks like a gizer, any help greatly appericiated
Old Jun 20, 2007 | 04:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C7AZ-3A674-A .. P/S Pump
The same basic p/s pump was used 1965/77 on most Ford cars & trucks.
D1AZ-3B584-A .. P/S Pump Seal Kit ~ Used on virtually everything: 1965/1977
Old Jun 21, 2007 | 10:09 AM
daveengelson's Avatar
daveengelson
What engine to you have, seem to recall topic came up some time ago where member experience simular problem with ps pump on 302, could be mistaken, not sure if ps pump was an issue, or pulley setup. Anyhow, perhaps ND, or another member can provide additional info.
dave
Old Jun 21, 2007 | 12:10 PM
banjopicker66's Avatar
banjopicker66
Here is another way to ID it for a replacement (2WD only, by the way, as far as I know):
1. Examine the PS gearbox, looking down on it, as installed in the truck:
a. Does it have 4 nuts with a square-ish aluminum cover on the top? If so , it is a Bendix PS gearbox. This one was used only '65 - '68 or '69, F100- F250.
b. Does it have 2 bolts with an oblong-ish iron cover on the top? This is the Ford Saginaw gearbox, used on F100- F250 from '68 to '79. Very common, and you can specify any year in that range for a replacement.
(Note: Both PS gearbox covers will have a centrally mounted adjusting stud with a locking nut in the top.)
2. Examine the PS pump design.
a. Is it a round steel metal cannister with a narrow pipe for a fill tube? Usually it will have a metal dipstick that pops in and out, with a rubber plug near the top of the dipstick just under the pull coil. If this describes your PS pump, this one was used up to '77 like ND said.
b. Is it an aluminum front body, with a plastic rear section, with a wide mouth for a fill tube, and the rotating plastic cap has the dipstick molded into it? Then it is the one used '78 and later.
The difference between them is in the mounting brackets, the way the PS pressure hose connects to the pump, and in some cases, the offset of the pulley. Otherwise they can both run the same PS gearbox.
I put a '76 PS gearbox to my '66 F-100. I used to have a '76 PS pump when I had the 352 FE in there, because it fitted the '76 brackets and pulleys. For the '76 pressure hose, I asked for one from a '76 F-150 with a 390.
When I put in a 460, I used the serpentine brackets, and went to the '78 style plastic bodied pump because the '76 cannister one didn't fit the aluminum one-piece 460 brackets. For this setup, I ask for the PS pressure hose from a '78 F-150 with a 351M (or a 400 if the clerk can't tell the difference between a 351M and a 351W in his computer).
The return line or low perssure hose is the same for all with the Saginaw/Ford PS gearbox.
Hope this helps!
Old Jun 21, 2007 | 01:36 PM
NumberDummy
dave
C7AZ-3A674-A Ford P/S pump: to be used with Ford gear boxes (regardless of engine size).
The SAME overhaul seal kit that this pump calls for, was used on many cars & trucks 1965/77. (Ford; Fairlane/Torino; Mustang; Maverick; Falcon; Bronco; F100/350; E100/350 yadda yadda yadda...)
D1AZ-3B584-A .. Seal Kit
