transmissions
Old Jun 20, 2007 | 08:33 AM
red148's Avatar
red148
transmissions
the 4.2 V6 is hooked up to a different transmission than the 4.6 V8, right? thanks.
Old Jun 20, 2007 | 05:55 PM
Xyzzy's Avatar
Xyzzy
I have the V6 with a 4R75E transmission.
I was told the 4.2L, 4.6L and 5.4L all share the same transmission.
(Well, you can get a M5OD with the V6.)
Old Jun 20, 2007 | 08:01 PM
red148's Avatar
red148
thanks. i thought maybe the V8s had something different for the autos.
Old Jun 20, 2007 | 09:12 PM
96f150's Avatar
96f150
xyzzy are you sure? I believe that only the 5.4L gets the 4R75E. Whats your trans code in the door jam? Just curious
Old Jun 20, 2007 | 09:51 PM
Xyzzy's Avatar
Xyzzy
0123456789
Old Jun 20, 2007 | 09:58 PM
Xyzzy's Avatar
Xyzzy
Model: 4R75E
Type: Four speed, rear wheel drive
Years: '04-'07 F-150
Engines: 5.4L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT)
Old Jun 20, 2007 | 10:14 PM
Xyzzy's Avatar
Xyzzy
Page 11 of this says 4R70E:
https://www.fleet.ford.com/truckbbas/non-html/2007/vs_pdf/f150_07bb.pdf
Dunno who to believe now. Is the 4R70E a bad transmission?
Another link:
http://t=41067
Old Jun 20, 2007 | 10:32 PM
Xyzzy's Avatar
Xyzzy
And another opinion, from my manual:
Old Jun 24, 2007 | 10:10 PM
Xyzzy's Avatar
Xyzzy
I'm still curious, even though the documentation points the the 4R75E. Is there a physical way to verify what transmission it is?
Old Jun 24, 2007 | 10:46 PM
Tom's Avatar
Tom
The way I understand it is that they redesigned the 4r70w tranny for the improved torque of the 3v 5.4, and called that the 4r75e. When they redid the electronic tranny controls they renamed the 4r70w to 4r70e.
You should have the 4r70e. This is the same tranny they used to stuff behind the 2v 5.4L v8s, and is known to be very reliable.
Old Jun 25, 2007 | 04:56 AM
PhqChevys's Avatar
PhqChevys
With all the posts on what trannys are what, or "what do I have" I thought it would be a good idea to make a total list for the full size fords.
For the engine listings. I'll break the common bell housing patterns in {}.
Heavy Duty Automatics
Model: C6
Type: three speed non electronic
Years:
'66-'90 F-series
'78-'89 Bronco
'91-'96 ('97?) F-2/3/superduty
Engines:{300, 302, 351w, 351c}, {400, 351m, 460}, {6.9L, 7.3L IDI}, {352, 360, 390, ect.}
Fluid:
Pre '77: Type F
Post '77: Mercon
Display: PRND21
Pan 17 bolts "Utah" shape
Ratios:
1st 2.46:1
2nd 1.46:1
3rd 1.00:1
Trans code: K
Model: E4OD
Type: Electronic Four speed Over Drive
Years:
'89-'96 Bronco,
'89-'98 F-Series
Engines: {300, 302, 351w}, {460}, {7.3L IDI}, {7.3L PSD}, {5.4L}
Pan: 20 bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E
Model: 4R100
Type: Four speed, Rear wheel drive, and 100(x10)lbs of torque
Years:
'99-'01 F-150's (rare)
'99-'04 Lightning's, F-150 7700'
'99-'03 superdutys
'03-'04 gas superdutys
Engines: {5.4L, 6.8L}, {7.3L PSD}
Pan: 20bolts
Fluid: Mercon
Ratios:
1st 2.71:1
2nd 1.54:1
3rd 1.00:1
4th 0.71:1
Trans code: E (gas), 9 (diesel)
Model: 5R110 “Torqshift”
Type: Five speed, Rear wheel drive, and 110(x10)lbs of torque
Years:
'03-'04 6.0L
'05-'07 Superdutys
Engines: {5.4L, 6.8L, 6.0L},
Display: PRN(D)321 w/ tow haul lockout switch
Pan ?
Fluid: Mercon SP
Ratios:
1st 3.09:1
2nd 2.20:1
3rd 1.538:1
4th 1.00:1
5th 0.71:1
Trans code: B
Light Duty Automatics
Model: AOD
Type: Four speed non electronic
Years:
'85-'93 F-150
'85-'89 Bronco
Engines: 302
Display: PRN(D)D1
Pan ?
Fluid: Mercon
Ratios:
1st 2.40:1
2nd 1.47:1
3rd 1.00:1
4th 0.67:1
Trans code: T
Model: 4R70w
Type: Four speed, Rear wheel drive, and 70(x10)lbs of torque
Years: '94-'07 F-150
Engines: {302, 4.2L}, {4.6L, 5.4L}
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: U
Model: 4R75E
Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque
Engines: 5.4L
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Manuals
Model: M5OD-R2
Type: Five speed Mazda Overdrive
Years: 88-96 Bronco, F150s
..........97-03 F150s
..........05 F150 (v6)
Engines: 300, 302, 4.2L, 4.6L
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
1st 3.90:1
2nd 2.25:1
3rd 1.46:1
4th 1.00:1
5th 0.80:1
Construction features: External Ribs in square patterns
Trans code: M
Model: SROD
Type: Four speed overdrive w/ push down reverse
Years: 80-83(4?)
Engines: 300, 302
Fluid: ?
Display:
P..R..1..3
U
S.....2..OD
H
Ratios:
1st 3.25:1
2nd 1.92:1
3rd 1.00:1
4th 0.78:1
Reverse 3.25:1
Construction features: Aluminum, shifter near back
Trans code: B
Model: NP-435
Type: Four speed non overdrive
Years: 80-87?
Engines: 300, 302, Your mostly gonna find it behind a 300.
Display:
1.2
3.4.R
Construction features: Cast Iron w/aluminum top plate, shifter in top, PTO Pass side
Fluid: 140w
Ratios:
1st 6.69:1
2nd 3.34:1
3rd 1.79:1
4th 1.00:1
Reverse 3.25:1
Trans code: A
Model: T18
Type: Four speed, non overdrive, non syncro first gear
Years: ?
Engines: 300, 302, 351, 460, 6.9L
Fluid: ?
Display:
1.2
3.4.R
Construction features: Cast iron throughout
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code: F or P
Model: T19
Type: Four speed, non overdrive, syncro first gear
Years: up till 93
Engines: 300, 302, 351, 460, 6.9L, 7.3L
Fluid: 140w
Display:
1.2
3.4.R
Ratios:
Gas
1st 6.32
2nd 3.03:1
3rd 1.79:1
4th 1.00:1
Diesel
1st 4.02:1
2nd 2.41:1
3rd 1.41:1
4th 1.00:1
Trans code F or P
Model: ZF5
Type: Five speed heavyduty overdrive
Years: 87-99 F2/3/450/superduty
Engines: 300, 351, 460, 6.9?, 7.3
Fluid: Mercon
Display:
1.3.(D)
2.4.R
Ratios:
S5-42 (Diesel)
1st: 4.14
2nd: 2.37
3rd: 1.42
4th: 1.00
5th: 0.77
Reverse: 3.79
S5-47 (diesel)
1st: 5.08
2nd: 2.61
3rd: 1.53
4th: 1.00
5th: 0.77
Reverse: 4.66
S5-42 and S5-47 (gas)
1st: 5.72
2nd: 2.94
3rd: 1.61
4th: 1.00
5th: 0.76
Reverse: 5.24
Trans code: 2
Model: ZF6
Type: Six speed heavyduty overdrive
Years: 99-06 F-superduty
Engines: 5.4, 6.8, 7.3, 6.0
Fluid: Mercon
Display:
R.1.3.(D)
L.2.4
Ratios:
L 5.79:1
1st 3.30:1
2nd 2.10:1
3rd 1.31:1
4th 1.00:1
5th 0.72:1
R 5.23:1
Trans code: 6 (diesel), 5 (gas)
Old Jun 25, 2007 | 06:01 AM
96f150's Avatar
96f150
Phqchevys, Thank you for all that info
Rich
Old Jun 25, 2007 | 01:25 PM
bamorris22's Avatar
bamorris22
Well, here's an official OASIS report for your truck. Sure enough, it says you have the 4R75E tranny. I too thought that only the 3v 5.4's came with that tranny. I thought that all the others came with the 4R70E. Oh well!
<TABLE width="100%" border=0><TBODY><TR><TD width="50%" bgColor=#be91f7>
Vehicle Specific Information
1FTRF12207NA22796
</TD><!-- <td width="39%" bgcolor="#BE91F7"><div align="center"></td>--><TD class=SMALLLABEL vAlign=top align=right width="11%" bgColor=#be91f7><SMALL>06/25/2007
14:20:09
FCXWS446
</SMALL>
</TD></TR><TR><TD width="60%" bgColor=white>
© Copyright 2002-2006 Ford Motor Company. All rights reserved.
</TD></TR></TBODY></TABLE><!----------- Message body ------------------------------><TABLE width="100%" border=0><TBODY><TR><TD vAlign=center width="100%" bgColor=#ccccff colSpan=5 height=40>VEHICLE INFORMATION </TD></TR><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="33%">VEHICLE DESCRIPTION
2007 F-SERIES LD</FONT< td>
<TD vAlign=top width="33%">BODY STYLE
F-150 REG CAB STYLE SIDE 4X2
</TD><TD vAlign=top width="33%">ENGINE
4.2L EFI
</TD></TR><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="33%">TRANSMISSION
4R75E 4 SPEED AUTO
</TD><TD vAlign=top width="33%">AXLE CODE
19
</TD><TD vAlign=top width="33%">ENGINE CALIBRATION
7F612A0A
</TD></TR></TBODY></TABLE><TABLE width="100%" border=0><TBODY><TR><TD vAlign=center width="100%" bgColor=#ccccff colSpan=4 height=40>GENERAL WARRANTY INFORMATION </TD></TR><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="33%">WARRANTY START DATE
03/26/2007
</TD><TD vAlign=top width="33%">BUILD DATE
09/09/2006
</TD></TR></TBODY></TABLE><TABLE width="100%" border=0><TBODY><TR><TD vAlign=center width="100%" bgColor=#ccccff colSpan=2 height=40>OUTSTANDING FIELD SERVICE ACTIONS </TD></TR><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="99%">NO CAMPAIGN MESSAGE(S) FOUND</TD></TR><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="99%"></TD></TR></TBODY></TABLE><TABLE width="100%" border=0><TBODY><TR><TD vAlign=center width="100%" bgColor=#ccccff colSpan=2 height=40>EXTENDED COVERAGES</TD></TR><TR><TD vAlign=top width="1%"></TD><TD vAlign=top width="99%">NO ESP INFORMATION AVAILABLE </TD></TR></TBODY></TABLE><TABLE width="100%" border=0><TBODY><TR><TD class=OASISNORMAL bgColor=#be91f7></TD></TR><TR><TD class=OASISNORMAL>End of Report for: 1FTRF12207NA22796</TD></TR></TBODY></TABLE>
Old Jun 25, 2007 | 03:10 PM
Xyzzy's Avatar
Xyzzy
Very cool. I always wondered what an OASIS report was. Thanks!
wicker63
Oct 24, 2016 06:54 PM
pcarr4
Escape & Escape Hybrid
Dec 15, 2015 07:00 AM
Samsn4
Ford Truck Parts for Sale
15
May 30, 2015 09:53 PM
paker
1997 - 2003 F150
17
Oct 1, 2011 07:59 PM
