94 F150 with alignment issues
Old Jun 19, 2007 | 07:57 PM
kellar's Avatar
kellar
I just replaced my pitman arm, 4 tie rods and both adjusters on the weekend. I have adjusted my steering alignment about 10 times now because everytime I turn the tires the alignment gets thrown back out. I don't know whats going on with it. I keep checking to make sure everything is tight but there is still something happening. Any suggestions?
Old Jun 19, 2007 | 08:01 PM
Bruce R Leech's Avatar
Bruce R Leech
are you talking about setting the toe in? if so check your wheel bearings for play.
Old Jun 20, 2007 | 06:37 AM
kellar's Avatar
kellar
The toe in is fine. The problem I'm having is in the steering. One wheel will stay straight and the other will turn in or out a bit.
Old Jun 20, 2007 | 10:30 AM
Bruce R Leech
you should be able to see where the play is if you have some one work the wheel while you watch under the truck.
Old Jun 21, 2007 | 05:33 PM
kellar's Avatar
kellar
I will have somebody steer it for me tomorrow. How tight should the tie rod end nuts be? These are the first tie rods I've changed so I am wondering if it is possible to have them over tightened.
Old Jun 21, 2007 | 05:46 PM
Bruce R Leech
the tye rod end clamps 52 to 74 lbs I would just make it 65 with anti seaz compond
Old Jun 21, 2007 | 07:08 PM
andym's Avatar
andym
I think I see the problem... you tried to align it yourself? By eye?
Or did you measure it? If you did, what did you set the toe to?
Old Jun 22, 2007 | 06:38 AM
kellar's Avatar
kellar
I am trying to align them with the rear wheels. I have never aligned anything before so I don't really know what I'm doing. I just gotta get it close enough to get to the alignment shop that is about a hour drive. I put a dropped pitman arm on because of the bump steer and changed everything while I was at it. I have 2" wheel spacers on my truck so I am going to remove them tonight and try it again.
