Computer Chips & Tuners
SUPERCHIP vs DIABLO CHIP
Old Jul 20, 2001 | 09:17 AM
DBUCKWILD's Avatar
DBUCKWILD
Can someone please tell me which is the better CHIP.
I am interested in a CHIP for my 99Expy 5.4 4x4. Mods
K&N Filter and dual exhaust Flowmaster with rear exist under the trailer hitch custom job.
I have talk to Danny at 2D's and his Diablo chip sounds good ?
I have also talk to Mike at F150nline.com and his Superchip sound
just as good if not better ?
I am still not sure which way to go?
I would like some feed back on this.
Did anyone really see any power gains from these's chips
Old Jul 20, 2001 | 01:34 PM
FTE Ken's Avatar
FTE Ken
Danny is our programmer - he programs them, we sell them). He/we sell both the Superchip and the Diablo. I almost always recommend the Diablo and Danny usually does too when he talks directly with the customer. Its a cleaner installation and a couple extra hp.
Ken Payne
Ford Truck Enthusiasts Admin
Old Jul 21, 2001 | 02:01 AM
bigfordman70's Avatar
bigfordman70
Which one do you/he like for the PSD? I've heard the Diablo's tend to run high egt's.
BFM
Old Jul 21, 2001 | 07:39 PM
D's Avatar
D
BFM: You are correct, partially. Some of the codes run hotter from Ford. So to say that statement is correct??? May be correct with some codes, on other codes the Superchip runs higher EGT's. You usually don't worry about high egt's caused by the chip unless you are towing a tremendous amount of weight, and have a hotter than recommended chip. Diablo seems to have gotten the egt's under good control. As for the 5.4, egt's are not a concern on any naturally aspirated gasoline engines.
Thanks
Danny
2001 Cobra-Lazer Red
3:73 gears
Steeda Tri-Ax Short Shifter
DiabloSport Chipped
Old Jul 28, 2001 | 02:50 AM
bigfordman70
Sorry, I should have been specific. Which chip do you like better for an '01 F-250 PSD 6-sp cc lwb 4x4 with engine code XPC4?
Thanks
BFM
Recycle...crush a chevy
Old Jul 28, 2001 | 07:26 AM
D's Avatar
D
BFM: For the XPC4 code, Superchips has a better program. We have yet to be able to reduce the smoke with a Diablo program in an XPC4. With a Diablo, the truck smokes so much you cannot see behind it. With a Superchip, it runs clean. This is the only code we have had a problem with excessive smoke, with Diablo. This is from personal experience from installation in 12 vehicles with XPC4 code. The experience has been exactly the same in each and every one of them.
Thanks
Danny
3:73 gears
DiabloSport Chipped
Old Jul 29, 2001 | 12:21 AM
bigfordman70
Thanks for the info Danny. I already knew I didn't want a Diablo, and until now I wasn't considering a Superchip either, so I have several more questions about them if you don't mind.
1. The online store on this site dosen't have an item discription, or dyno results for the PSD chip. What is the HP rating of the chip?
2. I assume it's the 65 horse chip, can I get a bigger one (80HP or possibly a flip) through this site?
3. Does the Superchip remove the speed limiter?
4. How much $$ to reflash (if it becomes necessary)? And,
5. Can it be reflashed for more power, or will I have to buy another chip later (this is where I'm leaning towards a flip chip, but geez, they're expensive)
Hmmm, can't think of anything else right now. Thanks for the help.
BFM
Old Jul 29, 2001 | 07:32 AM
D's Avatar
D
For dyno strips, go to Superchips.com or DiabloSport.com, both post dyno strips for the powerstrokes.
Both companies offer several different power levels. It really depends on how much weight that you tow.
Both companies can remove the speed limiter.
If you want the max power a chip has to offer, you will need a 4 inch exhaust system, a pyrometer installed, and will not be able to tow ANYTHING. Otherwise, a 78 hp and 156 ft/lb chip is the safest and maximum hp gain that you can achieve safely.
Thanks
Danny
3:73 gears
DiabloSport Chipped
Old Jul 29, 2001 | 07:05 PM
bigfordman70
Thanks.
BFM
Old Aug 24, 2001 | 09:06 PM
4WheelE350's Avatar
4WheelE350
Needing chip information quick! Is there a preventive of either company stationed in Orlando, Florida?
Old Aug 25, 2001 | 07:39 AM
D's Avatar
D
I'm sorry, I don't understand your question.
Diablo is in Boca Raton, they will not sell retail, Superchips is in Longwood, Florida, they sell for full retail price. Ken here is much cheaper than Superchips direct. If you have a question you need answered now, call me at 1-888-544-4626, we answer our lines 7 days a week from 8:00 A.M. until 10:00 P.M. CST. If I am not available, I will return your call shortly.
Thanks
Danny
3:73 Gears
Bassanni X-Pipe
DiabloSport Chipped
DenseCharger
Old Aug 26, 2001 | 12:17 PM
D's Avatar
D
LilBlackCoupe
Jun 2, 2004 04:16 PM
Tadashi
Apr 15, 2004 09:56 AM
bigslurrp
Mar 24, 2004 12:25 AM
Devil Dog
Jun 18, 2002 09:59 AM
chadrock
16
May 23, 2001 07:22 PM
