Sponsored by: Real Truck
what typically
Old Jun 19, 2007 | 03:25 PM
joeshmo's Avatar
joeshmo
what typically
What typically came uder a 2001 F350 SRW 4x4 ,gas, crew cab, axle wise, does anyone know. is a 12 bolt or a dana, if a dana which one. looking to put new gears in it. what gears would be recomended to run 37's
Old Jun 19, 2007 | 03:29 PM
BobbyDiesel71's Avatar
BobbyDiesel71
I have a 2002 F-350 Powerstroke Diesel 7.3 4x4 lariat
I have a DANA 60 up front and 10.25 Sterling rear end with 3:73 geas and a Limited Slip differential
it would depend on wether you have a 4x4 or 2wd gas or diesel,etc.
Old Jun 19, 2007 | 03:37 PM
joeshmo's Avatar
joeshmo
I have 4x4 gas
Old Jun 19, 2007 | 04:51 PM
redford's Avatar
redford
FTE Leadership Emeritus
If you look at your VIN then go to the Tech Folder at
https://www.ford-trucks.com/forums/4...lder_____.html
you can see exactly what you have under your truck.
Old Jun 19, 2007 | 09:02 PM
arcticoffroadingfish's Avatar
look at the axle tag it will say on there and plus dana put big whit barcoded sticker on their axles but the axle tag on the right will tell you everything gear ratio ring gear and if it is a dana or sterling....
Old Jun 19, 2007 | 11:58 PM
biz4two's Avatar
biz4two
Arrow
Up front: Dana 60
Out Rear: FORD Sterling 10.50"
To run 37" tires...you would want either 4.56's or 4.88's. The 4.88's if you plan on towing...
biz
