ARP main cap bolts
Old Jun 19, 2007 | 09:53 AM
w420_8's Avatar
w420_8
ARP main cap bolts
Rebuilding an 85 351w and was wondering what the best way to attach the oil pump pick-up was. The original bolt had a stud coming out of it. I will be using a sealed power HV pump. Can someone suggest a pick-up to use(stock is no more good) and how to mount it.
The arp bolrts are all the same with no studded bolt.
Thank you
Old Jun 19, 2007 | 08:16 PM
w420_8's Avatar
w420_8
speed pro HV pump
Old Jun 19, 2007 | 08:28 PM
HemiEater's Avatar
HemiEater
Same thing.......
look around you should be able to find a bolt and sump, just make sure the sump is made for the pan
