What all I need?
Old Jun 18, 2007 | 05:50 PM
zeaga's Avatar
zeaga
Question What all I need?
Hey Fellas,
I am about to change froma 3.55 gear to a 4.10. Beside the the Ring gear and pinion set, do I need the installation kit ant the bearing seals also?
Thanks.
Old Jun 19, 2007 | 10:59 AM
Cuda_jim's Avatar
Cuda_jim
It's always better to install all new bearings and seals, especailly on a high milage unit. IF you have never changed a ring and pinion before you might want to read up on all the measurements and setting that need to be right-on. There are special tools needed to make the switch. If any of the clearances and measurements are out of spec, all your $$ will go down the drain.
Old Jun 19, 2007 | 01:46 PM
mark a.'s Avatar
mark a.
What axle, axles ?
Old Jun 19, 2007 | 02:05 PM
andym's Avatar
andym
I don't mean to offend, but this very basic question suggests that you have no idea how to do this. A gear set needs to be set up properly with the right tools. If you don't know exactly what this means, then you will probably trash your new ring and pinion within a few miles.
Old Jun 19, 2007 | 02:48 PM
zeaga's Avatar
zeaga
Wink
I am just doing the purchasing. I will find someone to do the installation.
