'67 F100 Gas Gauge, ETC
Old Jun 18, 2007 | 12:55 PM
59pan's Avatar
59pan
my gauge works when I pull the sending unit and move it by hand, but it won't register right when I put it back in the tank. Suggestions....?
also...my dash lights won't come on. the bulbs are good, and the oil light does work...is there a fuse or other issues to look at?
I appreciate your time and help.
Old Jun 18, 2007 | 04:56 PM
jwtimme's Avatar
jwtimme
on the fuel tank make shure ther is a good ground between the sending unit and the tank if ther is no ground the gage will not read anything. check to make shure you have power to the dash I belive it a a lt blue wire with a stripe can remeber the stripe color
Old Jun 20, 2007 | 08:29 AM
J.O.S.'s Avatar
J.O.S.
My truck is a 1967 F100. I had the same two problems that you are having now, not long ago.
After checking all the grounds. I took out the sending unit to find that the float was leaking and full of gas. Replaced the sending unit. No more problems.
After R&R the instrument panel to check all wires, after replacing the ignition switch etc. no luck. I was getting ready to buy a new light switch , I turned the **** a little side to side till I came to "the sweet spot" and the dash lights work.
John O. Salazar
