Fuel Filter Warning Light
Old Jun 18, 2007 | 06:36 AM
ckal704's Avatar
ckal704
Question Fuel Filter Warning Light
Kepps flickering on at odd times. No real rhyme or reason....sometimes at cruising speed, sometimes at idle.
I put a new Motorcraft filter in and it still does it. Could this actually be an indication of overall low fuel pressure as a result of a weakening fuel pump?
Any ideas??
Also get a CEL every once in a while and that hadn't ever happened before.
Looking forward to any suggestions you folks might have.
Old Jun 18, 2007 | 08:51 AM
Cuda_jim's Avatar
Cuda_jim
This light is not an indication of fuel pressure, so it's not the fuel pump. Get it scanned to see if there is a stored code.
The plugged fuel filter sender on the side of the FPR may need replacing. Check the wiring too. It looks like an oil pressure sender. It's sometimes called a vacuum switch. Here's some part numbers for ya:
Fuel Filter Restricted sensor; on filter housing 94/95; on regulator block 96/97
(Ford) E8TZ-9S283-A
(International) 1809435c1
autofive
16
Aug 15, 2013 02:59 PM
ncycenas
Jun 13, 2013 08:37 PM
drad
19
Jan 17, 2013 12:27 PM
Brainard 66
Apr 23, 2009 12:37 AM
tank44
Oct 26, 2006 07:36 AM
