1978 - 1996 Big Bronco
89's not gettin fuel
Old Jun 17, 2007 | 09:22 PM
Flagtown FD's Avatar
Flagtown FD
I have a 1989 bronco with a 302 EFI.. none of the cylinders are getting any fuel but there is fuel pressure in the fuel rail and the wires leading to the injectors are getting power. I just replaced the fuel filter and blew air through the lines. does this sound like it could be an electrical/computer problem or something else..
Thanks, PETE
Old Jun 17, 2007 | 09:28 PM
khadma's Avatar
khadma
Carpenter Local 745
how much pressure are you getting at the fuel rail, and are you sure the fuel pumps are actually running? Could be many things- fuel pump relay, pressure regulator etc.
You may have to check each item and/or replace items as you go. It the parts ase all original- I would think about replacing some.
I have been there and done just that, the low pressure pusher pump(s) in the tank were the problem.
NashvegasMatt
17
Dec 12, 2016 12:12 PM
Chapabel
Jul 15, 2015 04:06 PM
68F100NY
15
Jun 24, 2015 08:38 PM
jrohr
Mar 7, 2015 01:43 PM
metfan85
Jul 20, 2003 02:25 PM
