Engine swap
Old Jun 17, 2007 | 04:06 PM
rjvaughan's Avatar
rjvaughan
Engine swap
Can someone tell me what it is about "Lincoln" 460 motors that makes them unusable in trucks? Is it related to mounts or ???
I have a '77 F150 with 351M/C-6.
Also, are 429 motors from cars (don't know they were ever in trucks) candidates? I know of a '71 Marquis that has a 429 available.
Thanks as always,
Rob.
Old Jun 17, 2007 | 04:07 PM
highboy1975's Avatar
highboy1975
you will need manifolds or headers and an oil pan for a truck. the car motors are front sump while the trucks are rear. other than that, i think theyre the same.
Old Jun 17, 2007 | 04:22 PM
rjvaughan's Avatar
rjvaughan
Thanks Highboy, that sounds so simple though I wonder why all the fuss. I don't mind buying an oil pan! If I were switching to a 429/460 then I'd be getting new headers anyway. As I understand it, both those engines should bolt to my C-6.
Old Jun 17, 2007 | 04:25 PM
rjvaughan's Avatar
rjvaughan
Here's another one .. can my C-6 be changed to bolt to a 302/351W? I guess that means changing the bellhousing?
Old Jun 17, 2007 | 05:09 PM
Mil1ion's Avatar
Mil1ion
Who told you they can be used ?
I have a 429 from a 70 Torino in my truck.
429/460 engine mount castings are the same.
Why are they wanted ?
Because they cam stock with 320 & 360 HP from the factory.
Please visit the 385 engine series forum for 429/460 topics.
Old Jun 17, 2007 | 05:16 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Thanks as always, Rob.
The mid to late 1970's Lincoln 460's were a de-tuned smogged up mess. No 429's were ever installed in F100/350's, but if you want to install a 429 in a truck, there's no problemo, as the mounts for a 460 will work perfectly.
429's were used in cars: 1968/1973.
Old Jun 17, 2007 | 05:17 PM
rjvaughan's Avatar
rjvaughan
Hi Dennis, thanks for the reply. LMC has mounts to do the conversion but they say "does not work on Lincoln motors". I am sure I read that elsewhere too. Always wanted to know the reason! Maybe they actually mean the really old Lincoln-Mercury engines (462 etc)?? Guess I would have to ask them.
Old Jun 17, 2007 | 05:20 PM
NumberDummy
Hi Dennis, thanks for the reply. LMC has mounts to do the conversion but they say "does not work on Lincoln motors". Huh? Why not?
I am sure I read that elsewhere too. Always wanted to know the reason! What reason? I've never heard of such nonsense! Ppl have been using 429's in F100/350's for years. What a crock!
462's are boat anchors, and are the latest and last version of the M-E-L 383's and 430's.
M-E-L = Mercury-Edsel-Lincoln Division.
lmc is NOT an FTE sponsor, so shop at your own risk.
Old Jun 17, 2007 | 05:50 PM
Mil1ion's Avatar
Mil1ion
These motor mounts from a 1978 4x2 truck with 460 are the ones I used on my 78 Truck 4x2 with 1970 429.
Old Jun 18, 2007 | 03:40 AM
NumberDummy
ALL 1973/79 F SERIES with a 460 (Econoline IS different) use same mounts and brackets
Engine Stands: D3TZ-6028-A .. R/S / D3TZ-6029-A .. L/S
Engine Mounts: 2-D3TZ-6038-A
Engine Mount Support Brackets: D3TZ-6030-A .. R/S / D3TZ-6031-A .. L/S >> NOTE: 6030/6031 = Shown in this illustration as R-6046.
Old Jun 18, 2007 | 08:43 AM
scottie2hottie's Avatar
scottie2hottie
That is how my 76 f150 2wd 460 are set exactly. I never though it was a factory 460 truck tho. I'll have to recheck that.
Old Jun 18, 2007 | 09:52 PM
rusty7983's Avatar
rusty7983
when you change the oil pan make sure you change the oil pump and pickup too.
Old Jun 19, 2007 | 03:27 AM
NumberDummy
..and the special stud needed to mount the pickup tube = D9HZ-6345-A > 3/8" -16 X 1/2" -16 X 4 7/8"
