PS conversion question
Old Jun 17, 2007 | 10:32 AM
1ole4d's Avatar
1ole4d
I'm getting ready to finish installing a power steering setup in my 1970 F100. I just had one question...I have two pullies for the swap. One is for the water pump and the other is for the crankshaft. Can I get away with just running the power steering pump off of the water pump or do I have to have it run off of the crankshaft? TIA
Old Jun 18, 2007 | 06:59 AM
390fe's Avatar
390fe
I'm running mine directly from the crank.
Old Jun 18, 2007 | 12:28 PM
jdgreen72's Avatar
jdgreen72
git'er. as long as it all spins, and belts aren't too tight, it'll work!
Old Jun 19, 2007 | 01:40 AM
redhawkssh44's Avatar
redhawkssh44
If you have both pullies then use them. It will keep all the belts lined up and evenly distribute the tension for longer belt and bearing life.
Old Jun 20, 2007 | 12:32 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Single belt for PS.
Why add extra bearing load on the water pump unless
replacing pumps is your thing?
Get the proper crank pulley and run the PS off the crank.
If it was a better idea to run the PS off the water pump why
didn't Ford think of it years ago?
