03 V10 Pulling 5th Wheel Camper
I am looking to buy a camper this week, a 04 challenger around 30' long. Im concerned about the weight. My owners manual says that my 03, f350, v-10, auto trans, SRW, crew cab, 4x4 w/ 3.73 gears can only pull around 9900 lbs. This trailer is claiming to weigh empty 9780 lbs w/ 12700 total weight. I am wondering if i keep it lightly loaded, and im not driving in the mountains just a few hills here and there will I be alright or is this a big no no. I guess im hoping the trailer really doesnt weigh quite as much as they claim and that my owners manual has some safety factor in its rating. I'm looking to only pull this trailer maybe a few times a month & only within 50 -75 miles from my home. Please tell what you think, does alot of people pull beyond the manual limits? And should i not buy this trailer due to weight limits?
You'll be fine. I have the exact same truck except in an F250 and have towed up to 12k lbs with it. My boat and camper together come in at around 11k lbs and other than the ocasional shift to 2nd on a couple 8% hills it does just fine. Even then I can maintain 65-70 up the hills although niether are more than a mile long. If you feel like you need a little more umph then do a gear job and switch them to 4.30s or 4.56s. The biggest thing to remember is when your backing up at the camper ground and find your self backing up an incline 4Low is very handy and takes a lot of stress off the trany.
The following users liked this post:
I'm looking at the 2004 Specs for 250/350's and it says your truck is rated to pull 10,200#. The DRW is rated at 9,900#. I think these specs apply to your 2003 also. As far as the weight of the trailer, I'd guess it weights more than what they're saying. According to the specs again, you have a GCWR of 17,000#. Anything less than a full truckload of people gives you more weight carrying/pulling capacity towards your GCWR. The same truck with a 4.30 rear end is rated to pull 12,500# with a GCWR of 20,000#. All that being said I don't think you would have any problems with the combination you are talking about.
It all comes down to this....
To tow anything safely, run the following numbers:
Take you GVWR from the door placard of the truck.
Take that number, subtract out the weight of the truck, full tanks of fuel, passengers, luggage, tools, toys, etc.
That will leave you with the number you can tow.
Take that number, subtract out the dry weight of your trailer, full water tanks ( 8 lbs x gallons), food, clothing, camping goodies, beer, and anything else you anticipate putting in the trailer.
After you do all this, hopefully you still have a positive number. If you don't, or it's too close, get a lighter trailer or a more robust pickup. It's really that simple. Oh.....and deduct 10% off your GVWR before doing any calculations if you tow in the Mountain West. Remember....getting the load moving is the easy part....getting it stopped (especially in a bad situation) is what's really important.
Good luck, and happy (safe) towing.
