Full float hub removal
Old Jun 16, 2007 | 07:21 PM
RollinHi95's Avatar
RollinHi95
I got a '93 F-250 with the full float rear end. What kind of tools do I need to get the hubs off. I'm in the process of changing brake shoes. My main problem is getting the nuts of. I tried a hammer and chisel , which I used on the front hubs, but the nut will only turn a little bit then stop. Their must be some kind of lock but it looks like nothing is holding it. Any idea's?
Old Jun 16, 2007 | 08:55 PM
subford's Avatar
subford
I take this is a F250 HD with a FORD rear end, if so.
Install Hub Wrench T85T-4252-AH so that the drive tangs of the tool engage the four slots in the hub nut.
CAUTION:
The hub nuts are right-hand thread (right hub) and left-hand thread (left hub). Each hub nut is stamped RH for the right hub nut or LH for the left hub nut.
Remove hub nut (counterclockwise for right-hand thread; clockwise for left-hand thread).
CAUTION:
Under no circumstances are power impact tools to be used when performing these operations.
NOTE:
The hub nut will ratchet during this operation.
Install Step Plate Adapter Tool D80L-630-7.
Install Puller Tool D80L-1002-L or equivalent and loosen hub to the point of removal. Remove puller tool and step plate.
Remove hub assembly.
CAUTION:
Do not drop outer hub bearing.
Old Jun 17, 2007 | 02:54 PM
RollinHi95's Avatar
RollinHi95
Great info, thanks. Yeah its a HD with the 10.25. I didn't know one was left handed thread.
RoughIdle
Dec 19, 2009 08:01 PM
hozee4
Aug 5, 2008 06:11 PM
gotdiesel
Apr 10, 2008 07:11 PM
muckypaws
Sep 25, 2007 03:43 AM
dickallen
Jun 30, 2007 11:15 PM
