Build sheet Gurus'....
Old Jun 16, 2007 | 07:08 PM
kuch73's Avatar
kuch73
I found what might be the last factory highboy, just high hopes but see post below, I cannot find the VIN on the frame, I looked though. The build sheet was under the seat, is there any way to tell on the build sheet if it is a highboy? Besides the VIN? The VIN on this truck is Y22325, but it has all of the stuff of a highboy. So what to look for on the sheet to see if it is? Thanks
Old Jun 16, 2007 | 07:17 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 1973/79 Ford Truck Parts Catalog states the last "High Boy" was made before serial number Y20,001. What is the full VIN?
Ford never called these trucks High Boys.
Measure the width of the rear frame, from frame rail to frame rail, post what the measurement is.
Old Jun 16, 2007 | 08:05 PM
kuch73's Avatar
kuch73
Frame is 34 at the tail end, VIN is F26HEY22325, Body FA4, Trans A, Axl B4J, it has old style steering, cab gas tank, divorced transfer case, outboard frame cab mounts. But it has a 351M, 4 speed, it "looks" all original, that's not to say it didn't have a cab swap in the past though. bought it from the 2nd owner. It has me confused! Build date is 3/77. It is close to the cutoff, could Ford be using left over materials? Truck sits way up too. Anything alse to look for?
Old Jun 16, 2007 | 09:23 PM
Jermafenser's Avatar
Jermafenser
The 351M/400 in 4x4s started in the '77 model year, so it's correct.
34" is also the narrow frame version.
F26 - F250 4x4
H - 351M
Y22325 - 1977
Trans A - NP435 4spd
B4J - Dana 60 limited slip w/ power steering
Look for the 4" factory blocks on the rear axle.
Old Jun 16, 2007 | 09:34 PM
Mil1ion's Avatar
Mil1ion
You already have this thread going
https://www.ford-trucks.com/forums/6...t-highboy.html
Please keep everything together so we don't have to look all over the place to see what has been mentioned.
Old Jun 17, 2007 | 08:54 AM
kuch73's Avatar
kuch73
I was going to use this thread as info for me to research, but it's turning into the same thread. Can a moderator merge the two? I looked at the lift blocks, they are the factory 4" with bump stops built in to them.
Old Jun 17, 2007 | 01:56 PM
Jermafenser
Sounds like it's an unmodified earlier 4x4 truck...maybe it was leftover materials. Who knows? After all, it's a FOOOOOORD!
