Motorcraft 2100 choke cap ?
Old Jun 16, 2007 | 04:02 PM
lud04X's Avatar
lud04X
The piece inside the cap marked "Lean" with an arrow on it where the spring hooks up to is broken. Is there a place where I can get just the cap? This is the cap which you loosen the three screws to turn. The spring inside is fine but doesn't have a place to attach on the inside of the cap.
Thanks
Old Jun 16, 2007 | 04:20 PM
Jermafenser's Avatar
Jermafenser
That would be the bi-metallic choke thermostat.
It can be bought just about anywhere. I found a few at rockauto.com.
Old Jun 17, 2007 | 12:17 PM
fmc400's Avatar
fmc400
MSEE
Yup, you should have no trouble finding that. Everytime I've bought a choke cap, they've asked for the carb numbers, so write those down if your tag is still attached. If not, if your old cap had a wire running to it, make sure you ask for an electric choke, as some chokes have a ceramic heating element to open up faster than with heat alone. Caps aren't cheap though; I typically see non-electric chokes up to $20 and electric chokes getting close to $30. There should also be a new gasket in the box.
Nick Wright
Oct 15, 2014 04:24 PM
Randy777
Aug 13, 2014 08:32 PM
Cougar54
Jul 20, 2014 04:30 PM
gmetime24
Jan 8, 2011 11:34 AM
Eric1967
Jan 25, 2008 10:29 PM
