speedometer quit.
Old Jun 16, 2007 | 03:41 PM
busted's Avatar
busted
speedometer quit.
any ideas where to begin ,my speedo quit and lost my digital odometer,its a 1995 f150..thanks.
Old Jun 16, 2007 | 03:50 PM
Bruce R Leech's Avatar
Bruce R Leech
check your connections to your tone ring on the top of the differential housing. then check your speedo control box under the dash and all the wiring in between
Old Jun 16, 2007 | 03:56 PM
busted's Avatar
busted
thayou kindly....
Old Jun 16, 2007 | 03:58 PM
busted's Avatar
busted
i meant thanks, my 1 year old son is on my knee.laterz.
Old Jun 16, 2007 | 04:00 PM
Bruce R Leech
check those things and get back to us. we will figure it out.
Old Jun 16, 2007 | 04:36 PM
NeXtras's Avatar
NeXtras
sounds more like a fuse.. check your fuses, should be fuse number 8 which is a 15 amp fuse. Very common problem with these model fords
Old Jun 16, 2007 | 05:15 PM
Bruce R Leech
Nextras is right any time you have a electrical problem check the fuses and breakers first.
Old Jun 16, 2007 | 10:21 PM
NeXtras's Avatar
NeXtras
the tranny probbably wont shift out of first unless u let off the gas and even then it shifts very hard. That fuse causes the spedo to go, odometer, courtesy lights. The spedo causes the tranny to shift weird and hard. My fuse has gone twice. If you have a trailer hook up, tape it up or cover it, i believe thats how i popped my fuse.
post back and let us know if thats what the problem was
Old Jun 26, 2007 | 11:27 AM
busted's Avatar
busted
all connections and fuses look good ,my brothers a lot better mechanic then me so ill let him have a go,thanks.
Old Jun 26, 2007 | 12:26 PM
95Ford4x4's Avatar
95Ford4x4
it's probably the vss on the rear axle. check the wires like Bruce said, could be a bad connection. next you can pull the sensor out and clean the end contact real good. if that doesn't work the sensor is probably bad and needs to be replaced. if you have an automatic don't drive it til you get it fixed the shifting of the automatics is controlled by the information from that sensor.
Old Jun 26, 2007 | 12:34 PM
busted's Avatar
busted
yeah thanks, ill attempt to crawl back under it and clean the terminals,but i have problems getting under my truck brcause of a motorcycle wreck and multiple surgeries to plate and bolt my pevis back together ,i hate not being able to hardly work on my truck anymore, i hate asking for help.
Old Jun 26, 2007 | 04:28 PM
95Ford4x4's Avatar
95Ford4x4
that sucks, i hate crawling under my truck cause i've got a bad back AND i'm just out of shape.
Old Jun 26, 2007 | 04:48 PM
NeXtras's Avatar
NeXtras
i really bet its a fuse, considering spedo quit with it
Old Jun 26, 2007 | 05:27 PM
87 f150 kid's Avatar
87 f150 kid
spedo problem
check your speedometer cable conection at the transfer case.
Old Jun 26, 2007 | 05:50 PM
busted's Avatar
busted
thanks for the help.
