Sponsored by: Auxito
1998 f150 door pannel removal
Old Jun 16, 2007 | 02:46 PM
morrponies's Avatar
morrponies
Talking 1998 f150 door pannel removal
My buddy has a 98 reg. cab f150. he needs to take off the door pannels but can't figgure out how any help would be grateful.
Old Jun 16, 2007 | 05:37 PM
galaxie641's Avatar
galaxie641
Lets see if I remember everything, the handle has a bolt holding it on, you need to remove the little cover shaped like a circle to access the bolt, I think its 10mm. Once thats off there should be a few screws at the bottom take them out and pull the A pillar cover straight off. Then it simply lifts straight up, forgot you need to pull the window door controls out and unplug them. I've had mine off enough I should remember but I have to many cars to keep track of which ones have what.
Old Jun 16, 2007 | 07:02 PM
Ultramagdan's Avatar
Ultramagdan
As said above. Remove the door handle, remove the plastic piece above the panel and then lift up.
shore
1997 - 2003 F150
15
Mar 2, 2014 10:07 PM
fordf150farmer
1997 - 2003 F150
Feb 2, 2010 06:26 PM
RustyTrustyF150
Mar 30, 2009 02:16 AM
morrponies
Jun 16, 2007 04:22 PM
88_Lariat F-150
Jul 11, 2003 10:57 PM
