#1 I have a meter that reads dc amps. I take my amp draw in series between the pos batt cable and the batt post itself. I am getting .43 amps with everything off. When I open the door I get 1.3 or something like that, from the dome light. Can anyone confirm if this is a normal reading (the .43 reading.). I know there needs to be a little amp draw for the radio memory but dont know what it should be. I have in the past had my new battery not start the truck after about 4 days & I know that there was a power bleed somewhere. This is why I started checking amp draw. I also think that the power bleed may be intermintent. Thank You.
#2 I looked at my timing mark & indicator thingy & the air pump blocks this. Why? I see know way to check the timing the way it is right now. Also when standing in front of the engine which way do I turn the dizzy to advance, cw or ccw. Thanks Todd.
remove spout hook up timing light, point it at damper, after you see marks, shut off engine and clean and mark the marks with crayon and then check timing.
you did not say what engine but the marks are not that hidden.
Turn distributer clockwise to advance. Air pump is not in the way. The hole is not the line up mark. I thought the same thing but it is the farthest part of the bracket towards the centerline of the engine,straght edge. Thats the way my 93 F-150 351W is.
Thanks guys. I'll look at it closer for the timing mark. I have already cleaned & marked the lines. Now back to my main concern. I think .43 amps is a bit high myself. The battery is new, & is the second new one. The first one was bad. Can someone check their amp draw with the truck not running & with the door closed if possible. I still think it may be in the ignition cylinder. Sometimes the door chime works & sometimes not. If its not working & I hit the steering column it will come on.Thanks Todd.
Todd, 13.4 is a bogus reading......either engine was running and was charging, or your meter was off.
A fully charged battery sitting idle with nothing connected should read around 12.75 volts.
I just checked my truck and made the following observations.
With the cable disconnected, I touched the cable end and the battery terminal with my meter in the 10 amp position. It momentarily had a .46 or so draw and then dropped to nothing no matter how long I kept it connected. I then disconnected for a while and as soon as I touched it again, .46 for a second then it dropped to nothing.
I repeated this several times to make sure that I wasn't just not connecting reliably.
I then switched my meter to the 200 ma mode and when connected it pegged for a while (probably .46 amp), then dropped to 6.5 ma. It stayed at 6.5 ma no matter how long I kept it connected. If I disconnected it for about 30 seconds or so, it would peg again when reconnected, then drop to 6.5 ma.
So I would say it should only draw that .4x amp for about a second, then only load your battery at 6.5 ma continuously.
If you have a continuous never ending draw of .4x amp then you do have a problem and it's probably not your battery.
netscaner. I appreciate the detailed explanation. Is ma micro or milli. I cant remember. Yes it stays at .43a. Also when I connect my positive cable or even when I check the amps with the 10a setting I hear a relay & a humm that sounds like the fuel pump. I'm wondering if the fuel pump isnt energizing & thats whats running down the batt. That is what leads me to think it may be the ign cyl. What do you think? Thanks Todd.
Try pulling the EEC Power relay, (not the Black & Green one) and see what you get. It sounds like your EEC Power relay may be stuck (welded) in the made position.
well, heres what I found. Last week I tried pulling all the fuses & the .43 stayed. This is why I was stumped. Yesterday I had alot of time to look at it so I installed my gauge pod & gauges. While working I was thinking that it had to be a seperate circuit that had its own fuse. I started looking around & found one such circuit. Cruise Control. It didnt work, at least thats what the previous owner said. I pulled the whole thing out. I think it was an aftermarket anyways. I figured if the thing didnt work why have it in the way. After pulling it I checked with the meter and now no amps were present. I hope this is the fix. Thanks for all your help. Anyone know where to get a new turn signal handle? Would it be in the Help section?
LMC Truck probably has it, or try 1stfordparts.com. I had a similar battery problem a few weeks ago with a Camry I just got ... turns out the keys were so worn out they came out of the ignition without being in the off position, a few times I reached in turned the key off, pressed the release and pulled the key .... that left it in the ACC1 position ... not the one that let the radio stay on but the one that kept the ECU hot and the clock on. I know I have left my radar detector on in my parked truck for a solid week and have been able to start it.
