AC Question
Old Jun 15, 2007 | 06:15 PM
CaptGuz's Avatar
CaptGuz
AC Question
well guys... i am flushing my radiator as we speak. i messed around with the AC that has never worked (heat has not worked either) and i noticed when i put my hand on the vent i feel nothing, if i switch it to heat i feel nothing and if i switch it to AC i feel the slightest little bit of air movement and i can also hear something working.
i know the belt is not on the AC compressor nor the smog pump.
what do you guys suggest as a possible fix? the blower doesn't seem to be blowing like it should.
Old Jun 15, 2007 | 09:06 PM
bustech81's Avatar
bustech81
if you can hear some noise than possibly your blower motor shaft is spining inside the fan assy.your a/c will not work unless you have the belt hooked up.
Old Jun 15, 2007 | 10:08 PM
CaptGuz's Avatar
CaptGuz
i realize the ac will not work without the belt. however, the heat does not work and the vent does not work either.
you mention the blower motor shaft spinning? how would i correct that?
Vince2307
Feb 28, 2015 11:16 AM
BMitch
Feb 27, 2015 06:43 AM
bulldogcountry1
Oct 22, 2009 11:23 AM
privatedog
Aerostar
Dec 8, 2004 10:34 PM
jmccraw23
Mar 14, 2003 12:14 PM
