Heat issues
Old Feb 27, 2015 | 08:51 AM
Vince2307's Avatar
Vince2307
Heat issues
Hey guys so as we know it's cold as can be right now, well my truck recently stopped blowing anything (heat,AC) from vents. Won't work on high medium or low but I did notice when I'm driving I can feel air coming through vents, if the heat is on its warm air. It seems the faster I go the harder the air blows then when Im not moving nothing comes out again. Any ideas on what this could be?
Old Feb 27, 2015 | 09:37 AM
farmert's Avatar
farmert
Do you have juice to the blower motor? If you do, I would say the blower motor has given up the ghost..
Old Feb 27, 2015 | 09:39 AM
Vince2307's Avatar
Vince2307
I'm not sure. How would I check? The other day I went on a long drive and it actually worked for a little so I could control it turned the truck off and it went away
Old Feb 27, 2015 | 09:51 AM
farmert's Avatar
farmert
If you have a test light, Key in the run position, engine not running, blower and heat controls in the high position, unplug the wire from the blower motor located in the engine compartment on the passenger side firewall. With the test light wire on a good gound, touch the test light point to the wire you unpluged. If you get a light, you are getting juice to the motor. If no light, your problem is farther upstream, possibly the switch itself, although I have not seen one fail.
Old Feb 27, 2015 | 01:04 PM
Vince2307's Avatar
Vince2307
I do not have a test light. I suppose I could maybe borrow one from orielly or somewhere? Am I unplugging the actuator wire?
Old Feb 27, 2015 | 01:24 PM
Hussler's Avatar
Hussler
Can you hear the fan running?
When at idle and turning the **** to vent anything blowing out of the defroster?
Old Feb 27, 2015 | 01:40 PM
sean9049's Avatar
sean9049
so at idle there is no forced air coming out of the vents, floors, or defroster, right?
Old Feb 27, 2015 | 04:32 PM
stainlessstroker95's Avatar
stainlessstroker95
Turn the fan on and then tap the blower motor And see if it kicks ok.
Old Feb 27, 2015 | 10:57 PM
Vince2307's Avatar
Vince2307
Correct at idle it doesn't blow at all nothing from any vent, I hit the motor a couple times and it kicked on I tried that again a couple days ago and nothing happened at all. I'm almost certain it's the motor just want other inputs. I also understand it could be the actuator but from my understanding if it's the actuator it'll only work on high
Old Feb 28, 2015 | 09:38 AM
farmert's Avatar
farmert
If the resistor is bad, the motor will only run in high speed, reguardless of where the speed selector is set. Sounds to me the motor is toast.
Old Feb 28, 2015 | 11:16 AM
Vince2307's Avatar
Vince2307
That's what I was thinking. Alright guys thanks for the help I'm gonna go get it today and see how it works
Seth_in_Maine
Dec 29, 2016 05:07 PM
Zgarriott1
1978 - 1996 Big Bronco
Dec 28, 2016 08:18 AM
82 F150
Jul 19, 2013 08:03 AM
American Air-1
Dec 3, 2012 09:54 AM
apgarcia3
Feb 27, 2010 05:31 AM
