Double sided tape removal
Old Jun 15, 2007 | 11:24 AM
61 uni's Avatar
61 uni
The previous owner of my truck mounted the drivers side vent visor so low that I couldn't open the vent window. I took the visor off yesterday and most of the tape stayed on the truck. How do I finish removing the tape without hurting the paint?
Old Jun 15, 2007 | 12:02 PM
MagKarl's Avatar
MagKarl
I'd use solvent, probably fuel to start with. I wouldn't step up to carb or brake cleaner till nothing else worked, that stuff can be hard on paint.
Old Jun 15, 2007 | 03:40 PM
Cuda_jim's Avatar
Cuda_jim
GooGone works great. You can get it at most grocery/hardware stores.
Oven cleaner works too, be careful with it. Soak it and cover with plastic wrap.
Have a beer or 2. Peel the plastic wrap, the glue should be sttuck to it. Scape what litlle bit may be left.
Old Jun 15, 2007 | 04:40 PM
Action4478's Avatar
Action4478
Have you tried a heat gun?...
Old Jun 15, 2007 | 07:15 PM
tjbeggs's Avatar
tjbeggs
wd-40 or brake cleaner
Old Jun 16, 2007 | 09:36 AM
Action4478's Avatar
Action4478
Hey T J...W D = BAD , it may work ok for that , but the stuff is a body mans nightmare....I'll tell you about it next time I see ya...
Old Jun 16, 2007 | 11:50 AM
MikeB 88's Avatar
MikeB 88
Used Goo Gone and a little bit of time, patience and elbow grease to get my tape off.
