Gages
Old Jun 18, 2007 | 08:54 AM
saddler53's Avatar
saddler53
Gages
I have a 2001 V-10,I'm haveing a problem with.After driving foe 30 min. to an hour the gages peg out (truck is not running hot)and truck cuts power.I can restart and drive a little futher ,gages are back in normal range.Has anybody got any ideas as to whats going on ,
Old Jun 18, 2007 | 01:40 PM
Monsta's Avatar
Monsta
Sit. Stay.
You might need a new battery. Batteries that worn low or "worn down" can do weird things.
Old Jun 18, 2007 | 01:49 PM
SRB X250's Avatar
SRB X250
I'm not an expert, but it sounds like an electrical short (or poor connection) causing the computer to lose power. I've noted when I disconnect the battery and reconnect it after a while the gauges will peg (and you lose all your radio stations). You may want to ensure your grounding wire is securely connected and it has good contact with the frame.
