droppin the rear
Old Jun 15, 2007 | 09:26 AM
BigDave74's Avatar
BigDave74
droppin the rear
i would like to lower the rear end of my 69 f100 but i cant figure out a good way to do it. ive heard of drilling shackles and lowering blocks but i dont know how i should do it. i only want to drop it a couple of inches so it will set about level with the front of the truck.
Old Jun 15, 2007 | 03:59 PM
Danger_Dave's Avatar
Danger_Dave
dont do that it will look funny
Old Jun 16, 2007 | 08:17 AM
Redcat Diesel's Avatar
Redcat Diesel
I've never lowered one but I'd suggest you talk to a spring shop.Leaf springs can be rearced to lift a vehicle so I imagine the same can be done to lower it.I would be careful as to how far you drop it though as it could create problems from bottoming out when you hit a bump. Hope this helps.
Old Jun 17, 2007 | 08:45 AM
jwtimme's Avatar
jwtimme
on these trucks you cannot use blocks because the axle sits below the leaf springs. You could dearch the spings but that will cost you at a shop and you will loose carring capasity. There is someone that makes shakels to fit these trucks but can't remember who this woluld probly be your best option, but if chep is name of the game then grind off the rivits that hold the shakel braket on drive out with a punch move up and drill new holes in the frame and reattach with grade 8 hardware.
Old Jun 17, 2007 | 11:14 AM
Slumlord's Avatar
Slumlord
If you're only looking for a few inches, just do and axle swap on the leaf springs(move the axle to the top of the leaf springs). I've done it on quite a few trucks just to level them out. You might have to get some new U-bolts, but for the most part it's a pretty easy modification.
jozan
Jun 6, 2012 08:45 PM
lil neet
May 5, 2011 10:11 PM
coreyhoward88
Mar 15, 2009 12:27 AM
4ced air lightning
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Dec 4, 2007 09:41 PM
wills79
Oct 7, 2004 02:39 PM
