wiring harness
thought you guys might find it useful
the part number is 10118
it covers wiring for: water temp,oil pressure, tach, coil, choke, a/c compressor clutch, high/low beam, park lights, turn signals, horn, wiper washer motor, brake proportioning valve, starter solenoid, voltage regulator, battery feed, alternator, 67-69 guage cluster harness, 1970-1974 cluster pigtail adapter, 1975-1977 cluster pigtail adapter, heater-a/c switch, headlight switch, turn signal switch, cigar lighter, glove box hazard switch, radio, tach, ignition switch, dimmer switch, brake switch, heater-a/c resistor, heater blower motor, wiper switch, wiper motor, cargo light switch, cargo light switch, door jam switches, courtesy lights, taillights, stoplights, rear turn signals, backup lights, liscense plate light, and fuel sending unit
it has the following switches: headlight, ignition, dimmer, wiper, and brakes
Will be installing one in the 68 when the time comes.
