Computer Chips & Tuners
How to remove a chip.
Old Mar 5, 2002 | 12:14 AM
Jakeman68's Avatar
Jakeman68
Do you have to totally remove a computer before you can remove/install a chip? Or can you just unhook the battery and pull the chip out of the PCM while still in my Expedition?
Old Mar 5, 2002 | 05:04 PM
FTE Ken's Avatar
FTE Ken
It is recommended that you have the wiring harness unbolted from the ECM when installing or removing a chip. I suppose you could remove it with the harness still plugged in but you run the risk of current from the sound system capacitors, etc. If you blow a chip through your own mistake, Diablo or Superchips may not cover it (though we've never had any sort of return issues with either).
Old Mar 5, 2002 | 05:08 PM
FTE Ken's Avatar
FTE Ken
