Propane setup Help???
Old 10-20-2007, 03:32 PM
mrwolf's Avatar
mrwolf
mrwolf is offline
I have this F700 truck I bought and it is running on propane.
It appears to be hooked up the gas tank as well.
Since I have never had a dual fuel truck before I was just wondering
how do you switch from propane to gasoline and vise versa.
There does not appear to be a switch anywhere.
can anyone let me know how this type of system works since I think
the timing has to be changed also if I remember right
Thanks
Old 10-21-2007, 08:09 PM
thosfsull's Avatar
thosfsull
thosfsull is offline
There might be a dual curve distributor like box sitting somewhere, looking MAYBE like a tin of altoids or two in size, shape, and color....
I just got a dedicated LPG 1997 F-700 last weekend with a 429. I ran out of the propane and was forced to convert back to gas on the spot for $300 in parts.
Old 10-22-2007, 09:13 AM
mrwolf's Avatar
mrwolf
mrwolf is offline
Mine is a 1995 F-700 with a 429
there has been a couple times when It just would not start so I want to be able to switch it back to gasoline when this happens and also propane dealers are rare where I am so being able to change it back and fourth would be great.
What parts were involved in changing back to gasoline?
Old 10-22-2007, 10:51 AM
gasman6674's Avatar
gasman6674
gasman6674 is offline
If you will send me a digital picture of the motor's lp equipment I can probaly tell you what to remove. If it has a dual curve on it you will have to remove it also and re-set the base timing. I have not seen to many 429's on dual fuel due to air flow issues.
Let me know
Regards
Gasman
1999-F150
1997 - 2003 F150
08-25-2017 03:23 PM
deisele75
Alternative Fuels, Hybrids & Mileage
18
07-02-2016 06:12 AM
Opossum
09-20-2012 05:53 PM
The_Relic
17
03-09-2012 11:48 PM
wabashtx
Modular V10 (6.8l)
09-01-2005 12:57 PM
Quick Reply: Propane setup Help???
