v-10 Bi-Fuel, need fuel pressure regulator, propane - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V10 (6.8l)
Reload this Page >
Modular V10 (6.8l)
Old 09-13-2004, 07:47 PM
wabashtx
wabashtx is offline
wabashtx is starting off with a positive reputation.
have a 2001 F-450 chassis cab with factory installed bi-fuel system, propane. Have had it since Nov. and have just over 37,000 miles on her. She quit running or starting in propane mode and local ford dealer said that the fuel pressure regulator was out. Good news is that warranty covers it, bad news is that the part is on back order until mid November. The truck only has an 18 gallon gas tank and being a v-10, well I have to stop at every station. Can someone help? Know how to fix or re-build? Back door for getting the part? I'm desperate, any suggestions appreciated!
Thanks,
Scott
Old 09-13-2004, 10:48 PM
daimon1054's Avatar
daimon1054
daimon1054 is offline
daimon1054 is new and has a neutral reputation at this point.
Do an internet search for a conversion kit for the Ford. The company that comes up will have a regulator. It might not be warrenty but it will get you going and you might be able to get Ford to pay! Also if it is going to be 90 days before they can fix you truck, from the time the problem started then you can call the lemon laws into action and make Ford replace your truck.
Old 09-14-2004, 06:28 AM
LANEGRA99
LANEGRA99 is offline
LANEGRA99 is starting off with a positive reputation.
Exclamation are you in the USA?
My family in Mexico they have always converted their pickup trucks to LPG becasue it si more efficient. any how I don't know if it would be illegal to run propane in the US. if you are in the US I'd be glad to know beacasuse my uncle can do the installation and parts for about 200 dollars is not less. AND believe me I would probably run LPG all the time.
Old 09-15-2004, 03:02 PM
jake00's Avatar
jake00
jake00 is offline
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
Its legal to run propane in illinois anyway. the local conservation district converted all thier trucks
Old 09-21-2004, 01:03 PM
jgarza250
jgarza250 is offline
jgarza250 is starting off with a positive reputation.
carefull LANEGRA99 this is what I also do for a living (install propane kits) and the Ford trucks need a special computer to run on LPG, this computer regulates the amount of propane going in to the engine and if you don't have this computer you have to regulate the amount of LPG by hand and on idle and once you punch in the gas it can cause a backfire and mess up your engine.
WABASHTX, what exactly did they tell you that was wrong?, Maybe I can get the part for you.
Old 08-25-2005, 11:09 AM
scrites
scrites is offline
scrites is starting off with a positive reputation.
LPG Conversion Kits - Ford V-10
Good Morning,
I have a 2000 Ford Superduty with the V-10 engine, I'm interested in converting to bi-fuel system....LPG/Gasoline.
Can you direct me where I can find a kit?
Thanks
Old 08-25-2005, 02:26 PM
V10KLZZ71S's Avatar
V10KLZZ71S
V10KLZZ71S is offline
V10KLZZ71S is starting off with a positive reputation.
These folks can find you some parts
http://www.fordpowerproducts.com/For...etrev10-04.pdf
Old 08-25-2005, 09:49 PM
Monsta's Avatar
Monsta
Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Welcome wabashtx!
Do you (or others reading this) know what the power output on a LPG equipped V10 is?
Old 08-26-2005, 12:19 AM
V10KLZZ71S's Avatar
V10KLZZ71S
Originally Posted by Monsta
Welcome wabashtx!
Mr Stroup, in my link, scroll down and they have power figures for the gaseous fueled V10's. Are they gonna swap to lpg on the islands?
Old 08-26-2005, 03:03 PM
Monsta's Avatar
Monsta
Monsta is offline
Wow...quite a drop. So in other words, don't do this if you tow.
With gas over $3 a gallon, LPG is not a bad idea. However, I do not know the cost here.
Old 09-01-2005, 12:57 PM
white99
white99 is offline
white99 is starting off with a positive reputation.
Ive looked for a bi fuel kit for a couple of weeks now and can't seem to find one. Ive called the local ford dealer and unfortunately probably spoke to the newest guy there, I called ford power products and they don't think they can sell one for a street legal truck. Can anyone give me a hand with this. 03 f-250 V-10. thanks for your help. JimP
AZFordLover
2017+ Super Duty
21
07-29-2016 09:14 AM
mario1987
1997 - 2003 F150
11-06-2015 01:05 PM
genegladden
1999 to 2016 Super Duty
12-21-2012 09:32 AM
bsparks72
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-18-2010 07:14 PM
azotos
Alternative Fuels, Hybrids & Mileage
10-17-2009 08:48 AM
Quick Reply: v-10 Bi-Fuel, need fuel pressure regulator, propane
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
