Computer Chips & Tuners
Chips for 86 F150????
Old Mar 6, 2002 | 03:51 PM
johnfl's Avatar
johnfl
I have an '86 that I put a 351w in but retained the computer for the 302. Is there a "chip" that works decent on the early EFI? I was told years ago that the on board computer would adjust itself to account for any chip and just return you to the original settings.
Whass up??
JohnF
Old Mar 6, 2002 | 03:59 PM
johnfl's Avatar
johnfl
I just read further down in the posts and Ken says it can be done. About what would it cost to purchase or have one made up? It's, as I mentioned before, an '86 5.0 computer with a '91 351w engine from a Bronco.
AOD.
4.30 gears.
Supercab with 33's.
Also, would I gain much running a cooler thermostat? It seems to have a BUNCH more power when it's not quite warmed up all the way.
Thanks
JohnF
Old Mar 6, 2002 | 08:23 PM
flyboy2610's Avatar
flyboy2610
Probably due to cooler, denser intake air.
Old Mar 6, 2002 | 08:54 PM
FTE Ken's Avatar
FTE Ken
No, the computer won't override the chip. But quite honestly, you probably won't be happy with a chipped 86 ECU. The gains are only about 5%. The cooler thermostat causes the truck to run richer. Yeah, it can sometimes give more power but it will also cause carbon build-up and higher emissions.
Old Mar 7, 2002 | 10:09 PM
ekufire's Avatar
ekufire
86--F250
Dec 19, 2012 10:39 PM
auggieinks
Jan 5, 2010 11:29 PM
86moneypit
Dec 23, 2004 09:09 AM
randallc
Alberta Chapter
Jan 11, 2003 06:32 PM
Dumbtruck
Mar 25, 2002 04:30 PM
