zf-6
Old Jun 14, 2007 | 03:51 PM
Lovin7.3's Avatar
Lovin7.3
zf-6
Hey guys Im kinda stranded right now so any quick help[ would be great. I have a 99.5 F250 with a 6 speed. I went to turn into my friends house and the clutch pedal stuck to the floor. I pulled it out and the clutch engaged but when i pushed it back in the clutch didnt disengage. any ideas??? thanks
Old Jun 14, 2007 | 04:04 PM
gunnertom's Avatar
gunnertom
Since no won has spoke up I'll try If your 6 speed has a slave cylinder look for leaks around thr dust boot an check to see if the shaft came out of the clutch fork.I hope this is a start ,,,,If nothing ilse its a bump to the top
Old Jun 14, 2007 | 04:17 PM
Lovin7.3's Avatar
Lovin7.3
the clutch sticks to the floor and when u pull on it it pops back really fast. im lost
Old Jun 14, 2007 | 04:44 PM
Lovin7.3's Avatar
Lovin7.3
i disconnected the slave cylinder pushrod. Is fluid supposta come out?
Old Jun 14, 2007 | 04:51 PM
gunnertom's Avatar
gunnertom
No If you pulled the dust boot back an fluid came out than the cylinder is bad.I've had this happin on bigger trucks I guess its the same on P/S.
Old Jun 14, 2007 | 04:53 PM
Lovin7.3's Avatar
Lovin7.3
yeah NO fliud came out. guess i will get a trailer and pull the tranny. thanks
Old Jun 14, 2007 | 04:59 PM
gunnertom's Avatar
gunnertom
I don't know were the heavy hitters are but they could give you some more advice.There are some people here that have zf6's an know a whole lot more than me''good luck.
Lovin7.3's Avatar
Lovin7.3
yeah thanks for the start much appriciated!
Old Jun 14, 2007 | 05:40 PM
F350-6's Avatar
F350-6
There are several possibilities. Unfortunately most involve pulling the transmission. I had a similar problem on one of our work trucks (99 250) and it turned out to be bent fingers on the pressure plate. If you're going through all that trouble I'd replace the throw out bearing while its apart. The clutch disc is expensive so that's your call. Check to make sure the fork is not bent, and if its the original rear main seal, they're pretty cheap once the transmission is out of the way.
Old Jun 14, 2007 | 10:59 PM
Highwood5's Avatar
Highwood5
I have a 2000 zf 6spd in my older truck and one thing to check/replace before pulling out the tranny is the spagetti hydraulic system. The newer model comes all complete from ford to minimize air in the system. If I remember the slave is only a quarterturn to remove from the tranny. Hope this helps a bit.
Old Jun 15, 2007 | 07:12 AM
bfife's Avatar
bfife
still plays with trucks
I'd say your clutch master cyl is bypassing internally. Happened to me 3 weeks ago. sitting in a campground with foot on clutch getting ready to disconnect the trailer and the clutch just slowly engaged. foot still on floor! pedal stayed on floor. pulled it up and pumped it a few times and it worked twice then no more. Change the master and all will be ok Barney
Carguy212
Oct 13, 2014 05:45 AM
Mishka0204
1983 - 2012 Ranger & B-Series
Sep 15, 2012 06:56 AM
Smokestack216
May 4, 2010 10:51 PM
geotracker91
Apr 26, 2008 04:35 PM
