Please Help
Old Jun 14, 2007 | 12:02 PM
dadshelper's Avatar
dadshelper
Please Help
My dad has a 95 f150 that will not start. He checked the fuel filter and that is ok and the fuel pump is getting power. He asked me to find a diagram for the wiring and I am having a difficult time with it. Guy at parts store said that we need a schematic diagram? Any advise? Thank you!!!
Old Jun 14, 2007 | 12:27 PM
95Ford4x4's Avatar
95Ford4x4
check to see if you are getting spark?? is it just turning over and over or is it doing nothing at all??
Old Jun 14, 2007 | 12:40 PM
subford's Avatar
subford
I take it you are talking about a fuel system schematic diagram with two tanks.
Old Jun 14, 2007 | 12:50 PM
dadshelper's Avatar
dadshelper
Thank you Thank you Thank you!!! I have been looking for days to find this!!! I can't tell you enough how my dad will appreciate this, he has been getting rides to work in my mom's toyota matrix every day and the guys at work are picking on him!
Old Jun 14, 2007 | 12:56 PM
Skandocious's Avatar
Skandocious
Hahah! Rightfully so Good luck dude.
Old Jun 14, 2007 | 08:38 PM
dadshelper's Avatar
dadshelper
Is getting spark and fuel in the line but no power to the fuel pump. Any ideas???
Old Jun 14, 2007 | 08:40 PM
dadshelper's Avatar
dadshelper
Is it alot different schematic if it is a single tank short box? He said he could probably figure it out from the original diagram but the single would be easier!! Thanks!~!!!
Old Jun 14, 2007 | 08:50 PM
ACarbone624's Avatar
ACarbone624
Did you check the Fuel Pump Relay?
Old Jun 14, 2007 | 08:54 PM
netscaner's Avatar
netscaner
I believe You started out this thread saying you had power to the fuel pump, and are now saying you have no power to the pump, and there is fuel in the line.
Are you/he aware that when you first turn on the ignition, the computer turns on the fuel pump just long enough to bring the lines up to pressure, then shuts it off.
It comes on again only after the engine starts, or until you shut off the ignition.....then on again.....and again only till it reaches pressure.
This is a safety feature built into most cars since the early 90's so that in case of an accident, the fuel pump doesn't keep pumping and possibly spewing gas all over.
Old Jun 14, 2007 | 09:11 PM
subford's Avatar
subford
This is for one tank.
The wiring power source is the same as the two tank diagram above starting at circuit 238 a DG/Y wire "N".
Old Jun 14, 2007 | 09:27 PM
rikard's Avatar
rikard
You should be able to hear the pump come on and shut off when you turn on the ignition. There should be a fuel pressure test port that looks like a tire air fill valve on the fuel rail. Depressing the pin will tell you if you have fuel pressure (be careful) On my 94 the pump failed at 120k and the harness connector to the pump (near the tank) failed at 165k.
I use an old spark plug with a grounding clip to test for spark. I think there is a TSB about an issue with the wiring with the ignition module and PCM. Check the FSB site.
good luck
rikard
Old Jun 15, 2007 | 04:45 PM
dadshelper's Avatar
dadshelper
It was the connector to the mercury switch is what I think that he said. I just want to thank all of you for all of your help! My dad says thanks, too! Now I am his favorite daughter!!! Thanks again, you guys are great!!
