Aftermarket Products
Sponsored by: Worksport
Keyless Entry
Old Jun 13, 2007 | 05:35 PM
coheaincolo's Avatar
coheaincolo
Keyless Entry
Well, I just bought a 2006 F250 without keyless entry and would like to now have it added.
Can anyone help me out with what my options are as I'm unsure if i need a whole alarm system...are there different ways of douing this etc.
Thanks in advance,
Chris
Old Jun 14, 2007 | 07:41 PM
F350-6's Avatar
F350-6
You can get the keyless entry added without an alarm. Most car audio or tint shops can do it for you if you don't want to do it yourself. They usually don't beep the horn when it locks, but it will lock/unlock your doors. I had one installed on my 02.
Old Jun 17, 2007 | 08:18 AM
pbeering's Avatar
pbeering
You can get a keyless entry setup from the dealer. Takes about 30 mins to install.
Old Jun 20, 2007 | 10:17 AM
hhott71's Avatar
hhott71
Keyless entry
keyless entry / alarm
keyless entry / remote start
keyless entry / alarm/ remote start
Its How much do ya want to spend?
A keyless entry is $35,, takes 20-30 min to install
www.bought4less.com
Old Jul 6, 2007 | 11:28 AM
T-Bilt_Niccolo's Avatar
T-Bilt_Niccolo
The only thing you have to make sure that you have are electric locks. If you dont then you have to buy the electric motors to lock your truck...etc and that would be a pain!
Old Jul 6, 2007 | 03:40 PM
soxfan81's Avatar
soxfan81
Thanks in advance,
Chris
do you have power locks? if so did you get a card with a keyless entry number on it?
Old Oct 24, 2007 | 12:27 AM
Tek69's Avatar
Tek69
I'm in a similar situation. I just bought a 99 F-250 XLT but I only got one key and no key fobs with it... its got power everything and the Ford parts guy looked up the VIN and said it looked like it should have keyless entry.
So I buy the fob and no matter what I do I cant get it working. So my question is how do I know for sure whether I really have the remote keyless entry module or not?
Old Oct 26, 2007 | 09:33 PM
chapinjohn's Avatar
chapinjohn
Tek69-This is on another thread....
Your trucks may be equipped with the keyless entry feature. To find out, follow this procedure for programming the key fob transmitters.
Place the key in the ignition and turn from LOCK to OFF. Then cycle between OFF and ON eight times in rapid succession (within 10 seconds) with the eighth turn ending in the ON position. The doors will lock/unlock to confirm that programming mode has been entered.
If you do this and the truck responds, then the truck is equipped with keyless entry and all you will need to do is to purchase some key fob transmitters and program them according to the instructions in your owners manual
Old Oct 28, 2007 | 11:01 PM
Tek69's Avatar
Tek69
Yeah, I did that dozens of times. Pretty much convinced I didn't have the option. Ended up having a nice after market alarm system installed along with keyless.
Thanks for the heads up though.
Old Oct 29, 2007 | 10:53 AM
chapinjohn's Avatar
chapinjohn
Tek69,
I am in the same boat. One key No Fobs. Had a key
made so I could get in out of the rain. Of couse
it will not start the engine.
Which alarm system did you have installed?
Old Nov 12, 2007 | 09:25 PM
Ford51's Avatar
Ford51
What position is lock, on and off? is on back with just the battery and lock is forward before ignition?
Old Nov 12, 2007 | 09:43 PM
chapinjohn's Avatar
chapinjohn
I only know about my Ranger, Its off to on (Not start)
four times and the doors will lock and unlock.
My 150 does nothing, but I have power locks.
Got a $65 quote from a radio place to add the
remote entry.
fordguy2236
1997 - 2003 F150
Jul 13, 2013 09:49 PM
ogbobbyjohnson
1997 - 2003 F150
Feb 11, 2012 09:47 PM
aldridgec
1997 - 2003 F150
Jan 26, 2003 08:54 AM
Aug 25, 2002 10:40 PM
loner
Electrical Systems/Wiring
Jun 11, 2002 02:43 PM
