1978 - 1996 Big Bronco
Locked Ignition!
Old Jun 13, 2007 | 05:02 PM
scbronco's Avatar
scbronco
Cool Locked Ignition!
hey guys
went to go start the bronco today and the key wouldnt turn the ignition cylindar
i tryed jiggle the wheel but i gave up after 10 minutes
help!!!
Old Jun 13, 2007 | 08:51 PM
96eddie5.8's Avatar
96eddie5.8
i had the problem too, on mine, the shifter **** was not fully in the park position. this was because of one of the linkages in the assembly had had a bolt fall out. replaced, and periodically tighten the bolt and it takes care of it. i know when to tighten it when the shifter has too much play.
Old Jun 14, 2007 | 02:28 AM
roger dowty's Avatar
roger dowty
yep...try holding the shifter up while turning key.
Old Jun 14, 2007 | 08:33 AM
scbronco's Avatar
scbronco
alright illl try that today
thanks ill let you know
