DieselSite Heater Core Bypass Mod Kit
Here's a parts list done up by Neal (Nlemerise):
Parts you will need:
1 - Autozone #74809 heater valve
5' of 3/16" vacuumline
4 - 7/8 or 1" screw clamps
1 - vacuum T-fitting
From this thread: Wow...REAL Air Conditioning!!
Originally Posted by tamte65
Which A/C plug (two black caps) should be used to check the refrigerant pressure. There's two, one in the front (bigger) and one in the top of the can (smaller). It should be checked from the low pressure side...
I bought the meter but it fits only to the smaller one. Just wondering if that's the right one.
The R134 fittings are designed so you can't get them backwards. The one right off the condenser (front) is the high-side, the one by the evaporator (back) is the low-side...
Joe
Originally Posted by firemediceric
With this kit installed, can I make the air a little warmer while on Max A/C or is the coldest air possible the only option regardless of the setting on the temp. wheel?
My truck gets pretty cool, but I would like to be able to make it even cooler. My wife often asks me to make it warmer. If I can't keep it set on Max to keep the humidity down while still bumping up he temp a little to keep the wife happy, the kit will be a no go for me.
Joe
Originally Posted by papadelogan
I did this mod and it doesn't seem to do much for me. I used the red vacuum line that's part of a bundle of 4 lines behind the glovebox but towards the center of the dash. As soon as you either 1) shut the engine off or 2) change it to OFF or any setting to the right, hot water flows in to the core. If you cut the flow of hot water to the core, sure it will cool down... eventually.
After installing the valve I checked to be sure the valve was getting vacuum, so I know I hooked things up right. But did I get the right vacuum line? And the T fitting had to be shaved down to fit in that tiny red vacuum line. I'll try and get pics of where I hooked things up, but I was really expecting MUCH more from this mod.
And I agree that when you shut the engine off, it will eventually lose vacuum, but there surely isn't any coolant flowing through the core with the engine off!! Like I mentioned earlier, I'll get temps of the outlet air with & without the valve closed and see what the difference is. I can tell that it's much cooler, but that's about as useful as the SOTP meter...
Joe
Originally Posted by Izzy351
It completely shuts off the flow of hot coolant to the core, so in Max, it's fully cold no matter where you set the temp ****. It works perfect for me, but you're right -- if you have a wife that likes it a little warmer, then you have to use a setting other than Max.
Joe
Joe
...you're supposed to use the large white vacuum line directly behind the kick panel that you have to take off under the glove box...
The provided tee fit perfectly.
Has anyone else use the red vacuum line for this mod? I went that way because I make a TON of body heat and with leather seats, summer's gonna be sticky, and that will be annoying. So who else has used the red line?
tamte,
Joe
Joe
And the meter showed pressure OK from that evaporator point. I was just curious and didn't want to spend any extra $'s in the shop.
This meter was like $14, it has the R134 can connection, I can check my wife's car too.
If it ever shows low pressure then I can march to the Wally's and buy small can of the R134. ~$5.
I heard that like every 5 years you should check the pressure.
Found this on the net and thought I would post for anyone that might be interested in building their own kit:
AC MOD
It will stop the flow of hot water through the heater core when the AC controlls are in the MAX setting and the OFF position providing cooler temps and preventing the hot pocket of air down by you feet. I went to NAPA and asked for the 'hot water shut off valve' from a 1990 Ford Ranger with a 4.0 V-6, I also got 4 - 5/8 hose clamps, a couple feet of 1/8" vaccume line a a 1/8" plastic "T" for the vaccume line. To begin the install loosen the cap on the radiator overfill to remove pressure from the system (do this while the engine is cool). On the passenger side of the engine compartment there are 2 - 5/8" hoses that come from the firewall and continue to the engine, these are the heater hoses. Cut the hose closest to the drivers side (It does'nt really matter where, I did mine about 6 inches after the fire wall). Then holding the 'shut off valve' with the vaccume controller twards the pass side install the portion of the heater hose coming from the cab to the top left nipple on the 'shut off valve'. Tighten the clamp. Install the portion of the heater hose coming from the engine to the top right nipple and tighten the clamp. Next cut the heater hose closest to the pass side in the same location as the previous. Install the portion coming from the cab on the lower left nipple, tighten the clamp. Now install the portion going to the engine on the lower right and tighten the clamp. Measure out how much of the 1/8" vaccume line you need to reach from the bottom of the vaccume canister on the shut off valve to the white vaccume line on the pass side that goes to the vaccume operated door underneath the pass side cowl. Cut that white vaccume line and splice in the 1/8" plastic "T". Then run the 1/8" vaccume line you meassured out from that plastic "T" to the nipple on the bottom of the vaccume canister on the shut off valve. It sounds more complicated than it is. Once you do it it will seem real simple. Happy trucking!
Thanks Bryan Central Texan
AC MOD
If I only wanted it to work on the MAX AC setting, that's true, but I want it to work on any setting to the left of OFF. There is a red vacuum hose that will accomplish this according to previous posts.
I didn't buy the kit from DIESELSITE so I had to buy a pack of T-fittings from the parts store.
Here's the pic of where I hooked up the vacuum line for the valve:
The clear coupler on the white line is unplugged from the silver part, a piece of vacuum line is plugged into it & the tee, then the coupler goes on the tee. The third side of the tee goes to the valve through the grommet, obviously. Super easy install...
Joe
#28
Ok, my DieselSite A/C kit just arrived. I looked the kit over and went out and peeled the carpet back and found the canister that you remove the vacuum line from. Looks like this should be a piece of cake.
One dumb question though, when I go to cut the heater hose do I need to drain coolant from the system first? If I don't drain and cut the hose is there going to be a torrent of coolant pouring out of the hose ends until I get the valve in place? I know that I shouldn't do this when the truck is hot and the cooling system is under pressure (like right now) but I am wondering about the above questions.
Thanks!
Thanks!
#29
