Motorcraft carb ID
The carb is leaking fuel from the front (accell pump?) I know the gasket around the top is bad because it was cracked when I fixed a leaky float 5 years ago.
My problem is I have no ID tag on it anymore (thank you PO). Would a generic rebuild kit help w/ this problem or am I in need of parts not included in those kits?
I wish I knew more about the engine but I'm unable to find any codes on the valve covers either...
Thanks in advance for any advice (and for your patience) I am pretty new to working on carbs, at least these kind. (I've done several motorcycle carb rebuilds)
-Chris
I will try and post some pics in my gallery or off my website as soon as I get a chance.
I did buy A rebuild kit for a motorcraft D7UEAPA... thats on my van. It is also a 351W 2bbl and yes I do believe CT-1077D was the number. So that might work on my carb that has no ID tag too? I was wondering just how generic these are. I guess I will find out soon. This will be my first rebuild on a ford carb any tips or tricks I should know? (other than take my time)
Thanks again!
Make sure to match the gasket to the carburator kit prior to opening.
Once the kit is opened and seal broken, there is no return policy.
Here a link that might help..
http://home.earthlink.net/~bubbaf250...rb/carb01.html
http://home.earthlink.net/~bubbaf250...rb/carb12.html
http://home.earthlink.net/~bubbaf250...rb/carb10.html
I was wondering just how generic these are. I guess I will find out soon. (other than take my time)
Thanks again!
Usually a 2150 Carb is the CT-1077D Kit
