code 176 thanks FTE
Old Jun 12, 2007 | 09:36 PM
Gary E's Avatar
Gary E
code 176 thanks FTE
Had some issues with another ranger today, 2000 3.0 auto. It shut down in traffic and at one point was blowing out black smoke running rich (thought it was running on ethanol)
First my code reader wouldn't even light up, searched here and found out I needed to check fuse 17, which was the problem.
Then got code 176, flex fuel switch/circuit searched again read Rockledges post here
https://www.ford-trucks.com/forums/2...d-ii-code.html
Was ready to hit the Pic n pull to see if I could find a switch since rumor is its $500. but then though I better follow Rockledges list and make sure I was getting a ground and power. Turns out the plug was full of water, blew it all out with the air hose and all is well. Thanks again Rockledge and FTE.
Old Jun 12, 2007 | 11:31 PM
RangerPilot's Avatar
RangerPilot
Try finding another post with Rockledge in it and give him a few rep points using the "scales" up at the top right corner of the post. Those are always appreciated and a great way to show that someone did you right:
And fixing things is very typical of him, expect nothing less.
Old Jun 13, 2007 | 06:45 AM
pawpaw's Avatar
pawpaw
Good trouble shooting, feedback & use of this forums fine information Gary.
Ditto Ranger Pilots suggestion, Rockledge is always a fine source of good useful info!!!!
Old Jun 13, 2007 | 07:56 AM
Rockledge's Avatar
Rockledge
You are quite welcome. It's good to hear that the forum is helping you save time and money.
mfp4073
Nov 26, 2014 11:47 AM
Rockledge
3.0L V6
Dec 6, 2006 07:53 AM
nightme_02
Jul 28, 2005 10:35 PM
dr76
40
Aug 11, 2004 10:54 PM
