Fuel System Question
Old Jun 12, 2007 | 06:53 PM
dynaride99's Avatar
dynaride99
I am troubleshooting my 2000 F250 and I am checking the fuel system now. When the key is on I can hear the pump run but not as loud as the trucks at work. I pulled the 1/8 pipe plug and it was dry. I then turned the key on and no fuel was present. I then had the truck started and no fuel. My question is how much pressure should I see at the rail.
Old Jun 12, 2007 | 08:12 PM
John311t's Avatar
John311t
You can check pressure at the fuel pressure port in the fuel bowl. Someone here should have a picture of where it is at. Good is above 50PSI all the time.
Old Jun 12, 2007 | 08:25 PM
Pocket's Avatar
Pocket
If you pulled that plug on the back of the fuel bowl, you should have fuel pouring out when you turn the key to the run position. If not, then your pump is gone.
Old Jun 12, 2007 | 11:39 PM
Tenn01PSD350's Avatar
Tenn01PSD350
This can be true. You may have an obstruction in the tank or lines too. The noise of the FP is not the best indicator, some are quieter than others. Another less messy way to check fuel flow is via the drain valve on the bowl to a container. The best way is via a gauge.
Old Jun 13, 2007 | 07:24 AM
dynaride99's Avatar
dynaride99
Thanks Turned out the pump was bad.
Old Jun 13, 2007 | 10:08 AM
SpringerPop's Avatar
SpringerPop
Was it a clogged inlet screen, or was the pump not running at all?
Pop
