obd II Question
Old Jun 12, 2007 | 06:06 PM
myakkacracka's Avatar
myakkacracka
obd II Question
I have a 1996 f150 and my check engine light came on and I have one of those pocket scanners frome discount auto parts and i tried to scann the code and it didnt work so i pluged it into another truck and it worked fine so i tested for power at the obd II port and there is no power has anyone ever had this problem
Old Jun 12, 2007 | 08:53 PM
mhg's Avatar
mhg
start by checking all your fuses
Old Jun 12, 2007 | 08:58 PM
96f150's Avatar
96f150
Check the fuse labeled "data link connector"
Old Jun 13, 2007 | 07:17 PM
myakkacracka
ya i checked all of the fuses to the PCM and the relay but they were all good were is the data link connector fuse in the panel or the powed distrbutation center
Old Jun 13, 2007 | 07:29 PM
91 F-150 Farm Truck's Avatar
91 F-150 Farm Truck
Go to autozone and tell them to use the big self powered scanner (OBD I and OBD II). They'll have to hook it up to your battery or cigarette terminal but it should work either way.
Old Jun 13, 2007 | 08:33 PM
96f150's Avatar
96f150
If memory serves me correctly, it is in the fuse panel under the dash. I remember it being on the same circuit as something else also.
Rich
Old Jun 13, 2007 | 08:56 PM
fordfaninIL.'s Avatar
fordfaninIL.
Usually it is the same fuse as the cigarette lighter.
Old Jun 14, 2007 | 05:47 PM
myakkacracka
yes that is what it is because my cigarette lighter does not work
