Timming chain position?
Old Jun 12, 2007 | 03:23 PM
Handegard's Avatar
Handegard
What cylinder am I setting to TDC when I set the timming chain?
I don't have any markings of any kind on my crank sprocket. I've looked, and my girlfriend and friend looked, just to confirm I wasn't crazy.
The Woodruff key for the sprocket seems to point straight up when #1 is TDC, but I'm not going to make a assumption like that
Old Jun 12, 2007 | 04:29 PM
airharley's Avatar
airharley
Front passenger side piston is #1.
Old Jun 12, 2007 | 10:30 PM
Handegard's Avatar
Handegard
Yes, so you're saying to have #1 at TDC then?
Thanks, Chris
Old Jun 13, 2007 | 09:45 AM
airharley's Avatar
airharley
That is correct. With #1 TDC and the timing marks lined up that simulates the piston would be ready to fire. Remember 4 stroke principles apply to all production engines: intake, compression, power stroke, and exhaust.
Old Jun 13, 2007 | 10:01 AM
3Mike6's Avatar
3Mike6
ANother Q...in regards to this thread...with cam dot at 6-o'clock and cranks at 12 (dot to dot) is #1 ready to fire, or do you have to spin the crank 360 and get both cam and crank at 12 O'clock to have #1 ready to fire?
Old Jun 13, 2007 | 10:16 AM
airharley's Avatar
airharley
Originally Posted by 3Mike6
with cam dot at 6-o'clock and cranks at 12 (dot to dot) is #1 ready to fire?
That is correct, basically the #1 being TDC is at the end of the compression stroke and needs the spark plug to fire to produce the power stroke.
deputydog03
1997 - 2003 F150
Nov 5, 2023 08:28 PM
Nathan Vos
Apr 29, 2017 02:20 PM
dionysius
Nov 22, 2016 01:30 PM
68shortbedmo
Modular V8 (4.6L, 5.4L)
Jul 15, 2014 08:53 PM
79smurf
May 15, 2014 03:38 PM
