front end shake after leveling kit install?
Old Jun 12, 2007 | 03:02 PM
viperbluelx's Avatar
viperbluelx
The front end of my truck shakes/bounces pretty bad only between 40-50mph after I installed the mini-spring pack to lift the front 2". Any ideas what would cause that?
Old Jun 12, 2007 | 03:28 PM
fbilly420's Avatar
fbilly420
did you have the alignment checked?
Old Jun 12, 2007 | 04:38 PM
viperbluelx
no, but I was told it wouldn't affect the alignment
Old Jun 12, 2007 | 05:01 PM
fbilly420's Avatar
fbilly420
was there any wedge shaped shims between the spring and axle when you took it apart?
Old Jun 12, 2007 | 05:03 PM
viperbluelx
no wedge shaped shims that I saw, if there was they were stuck to the upper or lower U-bolt plates. I just realized I forgot to tighten the track bar bracket bolts so it was moving around some, I hope that fixed it now that they are tight
Old Jun 15, 2007 | 06:47 PM
viperbluelx
anyone else?
Old Jun 15, 2007 | 06:57 PM
jrciii56's Avatar
jrciii56
That would make it shake. Drive it and let us know. Did you change tires and wheels?
