Basic 4 wheel drive question
Old Jun 12, 2007 | 01:01 PM
dcara's Avatar
dcara
My ESOF has 3 positions which are 2wheel, 4wheel High, and 4 wheel low. The manual says that when the hubs are set to the “lock” position that it overrides the ESOF. Does that really mean that when the hubs are locked that it is in 4 wheel drive and that power is sent to the front wheels even though the switch is in the 2wheel position?
A friend has a 4x4 06F250PSD without the ESOF. His 4x4 engages via a floor stick. He said that when his hubs are locked but the stick is in 2wheel drive that it does not power the front hubs. DO the 2 really work differently?
Old Jun 12, 2007 | 01:31 PM
countrycar's Avatar
countrycar
If your hubs are locked and the ESOF is not in the 4-wheel high or low,this will only spin your transfercase. If you are driving around town your fuel milage will suffer and also preamature wear on both the axle and the T-Case. Not a good practice. The ESOF has to be selected in order to lock the T-case so that the 4x4 will work.Take care.
Country
Old Jun 12, 2007 | 01:33 PM
Pocket's Avatar
Pocket
No they don't work differently. By manually locking the hubs, you are overriding the ESOF's ability to vacuum lock and unlock the hubs. However, if the switch is not in 4wd then there is no power directed to the front wheels. Remember the transfer case must be engaged for that, and the switch must be in a 4wd position for that to occur.
Old Jun 12, 2007 | 04:18 PM
dcara's Avatar
dcara
Ok. So the obvious question is why even have a hub lock/unlock position? Is it because of the possibility that the vacum line to the hub could get damaged; and if damaged then locking the hubs would be the only way to get 4wheel drive when the selector switch is set to 4 wheel high or low?
Is the Tcase engaged via vacum lines also?
Old Jun 12, 2007 | 04:31 PM
Green_Dually's Avatar
Green_Dually
The Tcase is electric,the manual lock is just in case the vacuum pump doesnt work,or if you have a leak and the hubs wont lock with the vac.
Basically for emergency use.
Old Jun 12, 2007 | 04:37 PM
countrycar's Avatar
countrycar
Maybe someone at Ford actually thought ahead and forsaw this as a potential problem. Well I actually worked for Ford for several years. Based on my research thru the Ford manuals, the axles will act almost like a limited slip when engauged automaticaly via the ESOF. When you feel you are going to encounter more serious terrain, heavy mudd, snow,Sand etc your advised to lock the axles Manualy for better Traction/Positive engaugement of the Front axle. Is this true? I'm not sure. But this is Fords reasoning behind the option. Take Care; Country
Old Jun 13, 2007 | 05:04 AM
konan's Avatar
konan
are you supposed to be able to manually lock both sides ?i have never been able to turn driver side on my 02 excursion,passenger side turns easily.thanks
Old Jun 13, 2007 | 05:17 AM
ford390gashog's Avatar
ford390gashog
Yes both should turn if not your hub is busted.
Old Jun 13, 2007 | 06:28 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Konan, i had the same problem as you. I went ahead and pulled the stock hubs out, and replaced them with Warn Premium manually locking hubs. No worries about vacuum leaks in my HVAC system, they look great and they do their job well. $180.
Old Jun 13, 2007 | 07:19 PM
konan's Avatar
konan
so if you want 4 wheel drive you just manually turn them and no need to use dashboard switch?or am i not understanding ,i would have no problem doing that just want to make sure i know what im getting into..thanks for the help.
Old Jun 13, 2007 | 07:40 PM
Pocket's Avatar
Pocket
The switch on the dash does two things. It vacuum locks the hubs, and it engages the transfer case. If you manually lock the hubs by hand, then that's all you've done. You aren't in 4wd until the transfer case is engaged.
Old Jun 13, 2007 | 07:47 PM
misterfisher's Avatar
misterfisher
Taking a tip form Guzzle's page, what works for me is going around the seam of the hub where the **** you turn is with some Silicone lubricant in a spray can, just unload it there. Then, get a piece of 2inch black PVC pipe about 5 inches long, and notch the ends. Your hubs will turn niceley with that tool and the shop of lube.
